Dang it. Sounds horrible.
My new dust collector motor sound wrong. Click link below to hear it.
Any suggestions as to what might be wrong?? How to fix? Take it back?
PS Harbor Freight, with Wynn Environmental MERV 15 Filter
...I already returned one bad part
LesB,
Tomorrow I'll take a peak inside.
The sound is intermittent & rhythmic.. Yes, I need to look inside, but I was thinking this is like a vibration thing… Like something's off center and triggering some harmonics, on and off..
Thanks
+1 remove the hose adapter and look inside. Could be a odd shape debris stick inside.
Had something similar as a long splinter of bark would get stuck on the housing weld, then rub until it was spinning around again; and repeated for several minutes till it broke into smaller pieces and was ejected.
+1 Pull the large impeller cover (yes, one with ALL those screws).
- Inspect for debris.
- inspect for loose impeller.
- remove the impeller and check for damage, loose rivets on fins, or bent impeller.
- spin the impeller on end of large screw driver, or shaft of socket extension; does it wobble?
- check inside of the housing for any rubbing.
- Is the motor mount perpendicular (90°) to the housing?
- Double check the mounting bolts to the sheet metal base. Could be loose.
- Now run the motor without impeller.
: IF noise is gone, figure out how impeller is making the noise.
: If noise is still there, then you have motor vibration issue. Could be lose motor mount, could be bad motor bearings, or even a bent motor shaft due rough handling during shipping.
Let us know what you find, and if I won a prize! LOL
I would at least pull off the impeller cover to check the clearance and hand turn the impeller to check for any rubbing before hauling it back to HF. It could be a very simple fix.
I have to say my HF one has been really good.If I had more $ I would have gotten a better one but this one hasnt given a bit of problems..I have had it in use for several yrs.
Solution: I returned the whole unit for a new one. New one sounds fine!
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
