How would you make this(fast)
« back to Joinery forum
Forum topic by CWWoodworking posted 09-23-2020 09:37 PM 508 views 0 times favorited 11 replies Add to Favorites Watch
View CWWoodworking's profile
CWWoodworking
1092 posts in 1061 days
09-23-2020 09:37 PM
Approximately 18×24. Looking for an easy way. Pic is sideways
11 replies so far
View bondogaposis's profile
bondogaposis
5872 posts in 3234 days
#1 posted 09-23-2020 09:45 PM
I wouldn’t touch that design, there doesn’t appear to any accommodation for wood movement.
-- Bondo Gaposis
CWWoodworking
#2 posted 09-23-2020 09:58 PM
I wouldn t touch that design, there doesn t appear to any accommodation for wood movement.
- bondogaposis
This is a sample I kinda threw together last minute. Any joinery I use, I will accommodate for movement.
View SMP's profile
SMP
2664 posts in 788 days
#3 posted 09-23-2020 10:21 PM
Fastest? Assuming frame is 3/4-7/8 and planks are 1/4”-1/2” or so, Dado a groove in the frame to accommodate planks and pocket screw the frame together.
View bilyo's profile
bilyo
1167 posts in 1985 days
#4 posted 09-23-2020 10:39 PM
Would biscuits be any better/worse than pocket screws? Not sure. They wouldn’t take any longer and, at least, would look better from the back side, if that matters. Dowels would only take a little longer and would be a whole lot stronger than either.Once set up, half laps would go fast too.
CWWoodworking
#5 posted 09-23-2020 10:50 PM
Everything is 13/16. I have no way of changing that. the frame isnt the problem. Making all the 45 cuts takes the most time. currently its just screwed to a 1/4” backer board. thought about making panel first. Dont know if that would be faster.
View weedeater64's profile
weedeater64
62 posts in 894 days
#6 posted 09-23-2020 11:17 PM
M&T frame with interior groove to accept the tongues on the panels.
View Loren's profile
10712 posts in 4530 days
#7 posted 09-23-2020 11:50 PM
You could ship lap the panel parts and nail them in a rabbet to the frame, installing moulding on the back to cover the uneven ends and nails. That will allow wood movement. You could skip the ship lap and leave 1/8” gaps between the pieces too, though light will come through.
View SMP's profile
SMP
#8 posted 09-24-2020 12:32 AM
- CWWoodworking
Then glue them together into a panel, and cut at 45 into a panel that will fit into the frame + groove, then rabbet the edges of the panel to fit into the groove, leaving space for movement.
View pottz's profile
pottz
11708 posts in 1867 days
#9 posted 09-24-2020 12:33 AM
i did something similar with a kitchen i did way back,i made the panels first and then used them in a traditional shaker style door.how many are you talking about? as far as wood movement no big deal,just allow for it,too many get all freaked out about it.i like the look,do it.
View Spaceballs's profile
Spaceballs
9 posts in 30 days
#10 posted 09-26-2020 03:51 AM
Why not use a piece of plywood, notch out the part that is missing and staple or nail with glue some various thickness boards to give you the appearance of the all that labor. Just saying….
-- Mark of Dixie Woodcraft
View John Smith's profile
John Smith
2725 posts in 1045 days
#11 posted 09-26-2020 01:16 PM
C.W.W. – have you started your project yet ?
I’ve done a couple of projects with 45* angled boards.
I first laid all the boards out on the table (or floor) to get the best pattern match.
then lay out the pattern, fasten the boards together as to whatever works for you.
and run the circular saw on your designated lines and cut all the boards at once.
[sort of like trimming a wooden deck of the excess ends to make them uniform].
since your project is so small, you can make a quick template of the inside frame,
move it around on the angled boards until you find the design that you like best,
mark each board with chalk so they can go back in order.
draw out with a Sharpie, cut each board with a chop saw. (only make one panel at a time).
the object is to have all the corners match within the design. as you can see in your
example photo, the top left corner does not match the bottom right corner.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
