Types of grease used in power tools
Forum topic by ed23 posted 09-22-2020 05:13 PM 378 views 0 times favorited 9 replies Add to Favorites Watch
View ed23's profile
ed23
60 posts in 114 days
09-22-2020 05:13 PM
What type of grease is used in power tool gear boxes, sabre saws, circular saws, etc.
9 replies so far
View Loren's profile
10712 posts in 4530 days
#1 posted 09-22-2020 05:16 PM
lithium grease I think. You can get stuff rated for worm drive saws and it wouldn’t surprise me if it’s fine for other applications as well.
View pottz's profile
pottz
11708 posts in 1867 days
#2 posted 09-22-2020 06:43 PM
for skil saws use skil 80111 saw lubricant it’s like the consistency of honey,other tools check what they recommend or you could be paying big tool repair costs,trust me i used to repair tools years ago and had many skil saws with the worm gears totally destroyed by using the wrong lubricant.
View Madmark2's profile
Madmark2
1714 posts in 1471 days
#3 posted 09-23-2020 12:35 AM
white lithium grease is my go-to for most anything. Its waterproof, easy to apply and a little goes a long way.
Most all bearings (with a ZZ suffix) are sealed and don’t need lube. But worm gears and such like a dab now and then.
-- The hump with the stump and the pump!
View SMP's profile
SMP
2664 posts in 788 days
#4 posted 09-23-2020 03:13 AM
I use white lithium grease or synthetic wheel bearing grease for that type of stuff if enclosed .i always have both in the garage. I just try to match up what was originally in there. Of course some things like worm drive saws may be completely different, like the kind with oil etc.
My 2 go to(note the valvoline grease is labeled NLGI #2 grade lithium complex EP grease
View bigblockyeti's profile
bigblockyeti
6786 posts in 2603 days
#5 posted 09-23-2020 01:53 PM
I was a tech working primarily with Milwaukee and Senco but serviced and repaired all other major brands as well. Milwaukee seemed to have a different grease for nearly every model, some of it was expensive. Now my go to is Valvoline waterproof bearing grease with lots of molybdenum. I’ve used it in everything from circular saws to Sawzalls to jig saw. It is not suited for worm drive applications, they need the correct oil or the brass worm gear will be destroyed.
pottz
#6 posted 09-23-2020 02:06 PM
back in the eighties we kept getting nail guns coming in that wouldn’t fire properly,opened them up and it looked like someone had poured a strawberry milk shake in there.we find out they were using trans mission fluid,seems another tool repair company was telling guys to use it.i guess they wanted more business-lol.
bigblockyeti
#7 posted 09-23-2020 02:16 PM
I had a few of those too. Not sure who might suggest that but if the o-rings aren’t compatible with ATF, they won’t last long. Most in pneumatic tools aren’t.
View LesB's profile
LesB
2622 posts in 4326 days
#8 posted 09-23-2020 03:46 PM
Always use caution in “mixing” grease lubricants. The are made with a variety of what they cal “soap” bases which is the thickener for the lubrication elements and constitutes 80+% by volume of the product.. Common soaps are, aluminum, calcium, sodium, and lithium. They do not mix so if you don’t know what you have be sure to clean the old grease out thoroughly before adding more.
White lithium grease is what I usually use on my tools.
-- Les B, Oregon
Rick Dennington
7013 posts in 4077 days
#9 posted 09-23-2020 04:38 PM
On any of my machines that are “gear and chain driven” I use the old style “axle grease” (been around since before I was born), but on “delicate gears and ball bearings, such as fishing reels, etc., I use the white lithium grease. On nail guns, etc. I use the recommended oil that comes with each one. Some 3-n-1 oil on other things like table saw motors.
-- " There's a better way.....find it"...... Thomas Edison.
