Sanding Western Red Cedar and Removing Sanded Dust?
Forum topic by rossn posted 09-22-2020 05:30 AM 374 views 0 times favorited 3 replies Add to Favorites Watch
View rossn's profile
rossn
72 posts in 680 days
09-22-2020 05:30 AM
I have a project, though more of a construction project, and less wood working. I’m putting up Western Red Cedar (select tight knot) under my soffits. The cedar has a planed and rough side, and the planed side will be visible.
Prior to staining the wood I am using a random orbital sander to removed the crushed surface, caused by the planing process.
After sanding a few sample boards, then wiping with a damp cloth, it seems the knots still have a white appearance from the dust (after drying). I wiped pretty thoroughly, but still some are whitish in appearance.
Is there a good trick to to remove the sanding dust, easily? That is the biggest challenge at the moment, and I have a few thousand feet of this wood to go.
Also, I experimenting between 80-grit and 100-grit. Does anyone know what grit is optimal for opening the pores in WRC?
Thanks!
Ross
3 replies so far
View vind's profile
vind
30 posts in 2197 days
#1 posted 09-22-2020 05:39 AM
try 120 – 150 grit and compressed air or vacuum
-- History recalls how great the fall can be. Supertramp, Fools Overture
rossn
#2 posted 09-22-2020 12:46 PM
So, moving up in grit will make the dust easier to remove from the surface before stain?
View Axis39's profile
Axis39
357 posts in 483 days
#3 posted 09-22-2020 01:37 PM
Air compressor and a blower nozzle. I;’ve sued a leaf blower a lot for things like this as well.
-- John F. SoCal transplant, chewer uppper of good wood
