need advice on saw till
Forum topic by Karda posted 09-21-2020 05:34 AM 301 views 0 times favorited 6 replies Add to Favorites Watch
View Karda's profile
Karda
2534 posts in 1437 days
09-21-2020 05:34 AM
i build a saw till, my first large project but the saws don’t fit right. The only way they fit is teeth out. What can I do to fix the till so i can put the saw teeth in. If I do this the way it is the saws fall out thanks
View drsurfrat's profile
drsurfrat
157 posts in 70 days
#1 posted 09-21-2020 12:15 PM
Can’t really tell what the exact problem is, but maybe a secondary bar (like a towel rack) on the lower front panel high enough to catch the horns of the saws.
-- Mike (near Boston) ... Laziness is the mother of invention, necessity is the mother of exhaustion - me
View bandit571's profile
bandit571
26729 posts in 3567 days
#2 posted 09-21-2020 02:31 PM
Maybe lean it back at the top? Add a 20 degree wedge to the bottom of the til, so the til will lean back at the top.
Or, build one like this?
Karda
#3 posted 09-21-2020 09:48 PM
thanks, think I can make a bar across the front
Karda
#4 posted 09-23-2020 05:40 AM
I figured i need a bar across the front about 2” from the front, that will give the saw enough lean so they won’t fall out. My question is how do I do this without making the till look like a piece of junk. there is a picture with out the saws and one with a brown triangle piece I had, something like this may not look bad but i am not sure how to go about it. I have a piece of 1 1/4 dowel I can use thanks
View PCDub's profile
PCDub
222 posts in 1128 days
#5 posted 09-24-2020 07:38 PM
It looks in your earlier pictures that the bottom piece on which the handles rest needs to be further away from the back to allow you to turn the saws around. If you can add a “wing” on each side that holds the dowel away from the current front of the till, that might work. Here’s a crude “sketch”
Karda
#6 posted 09-24-2020 08:41 PM
I know that is what I need to do, I want it to look good but I guess that won’t happen. anything I do will look like a patch. Thanks mike
