Do I need a composite pin nailer
Forum topic by 12bar posted 09-19-2020 03:30 PM 399 views 0 times favorited 14 replies Add to Favorites Watch
View 12bar's profile
12bar
57 posts in 1414 days
09-19-2020 03:30 PM
Topic tags/keywords: tool sawstop break and 23 gage pin nails
I have a Sawstop job site table saw. I need to use a pin naiker and I am wondering if I need to use a composite pin nailer if I cut through the pin of a 23 gauage pin. I had a salesman tell me that if I use a 23 gauage pin I can saw through the pin pin after the glue dries without setting off the safety break. Since I set it off once just by tipping the saw a blade angle a little to close to the aluminum Incra miter gage and just ticking the top edge I am skeptical of this salesman statement. I was thinking I needed a composite nail gun which would use plastic nails.
I know I can put the saw in bypass mode and cut the 23 gage nail ok but I am wondering about if I left the saw in it’s regular safety mode would I trigger the brake. Any thought or experience would be appreciated.
12 bar
-- 12 Bar
14 replies so far
View CWWoodworking's profile
CWWoodworking
1093 posts in 1065 days
#1 posted 09-19-2020 03:51 PM
I’d be shocked if the nails don’t trip it. Put it on bypass and cut.
View LeeRoyMan's profile
LeeRoyMan
1423 posts in 613 days
#2 posted 09-19-2020 04:00 PM
What you need to do is quit cutting through nails… :)
12bar
#3 posted 09-19-2020 04:49 PM
Leroy that is a good idea but I need to take apart the cabinet. I can do it by putting the saw in bypass mode as the brads are 18 gage and my carbine blade will cut the brad fine but I am wondering about if it would set the brake off if I were using 23 gage nails as the salesman said 23 gage nails would not set off the brake. Of course if I hadn’t made the mistaking the first place this wouldn’t be a problem.
When I build my my other cabinets since this first one I have made sure everything was squared. My mistake was just accepting that since I was using a pocket hole jig that automatically the sides would be at 90 degrees. Bad assumption and now the back and top are on it so I either need to shim the drawers which are square or saw the cabinet apart and redo irately making it square.
-- 12 Bar
View JackDuren's profile
JackDuren
1344 posts in 1845 days
#4 posted 09-19-2020 04:52 PM
They usd composite nail guns on CNC’s
12bar
#5 posted 09-19-2020 05:58 PM
I took the suggestion of turning the cabinet around and measuring diagonally from the outside instead of the inside from the front.
BIG DIFFERENCE! Outside dimensions are 33 1/4 by 33 5/16. So I am only out of square 1/16 of an inch. I then put a carpenter square checking all the corners on the outside and the corners are either square or 1/16 on one corner and 3/32 on another corner.
I think now with all your help, and thank you for all of it, my drawers will fit even if I need to shim one about 1/16”.
-- 12 Bar
View AlanWS's profile
AlanWS
88 posts in 4444 days
#6 posted 09-19-2020 08:14 PM
As long as the nails are not contacting the saw table while you cut them, they should not trip the Sawstop. I have cut through an unfortunate number of nails with mine, without triggering it.
If you want to find out, leave a nail sticking out of a board and while the saw is turned on but not spinning, touch the nail to the blade without your hands on metal. Watch the lights on the switch. They will blink if it would have triggered while moving.
-- Alan in Wisconsin
CWWoodworking
#7 posted 09-19-2020 09:45 PM
- AlanWS
So how would one cut through the nail without touching the table?
View Madmark2's profile
Madmark2
1725 posts in 1474 days
#8 posted 09-19-2020 11:16 PM
It’s an electrical thing. As long as the nail isn’t contacting the metal saw top when the blade hits it, the saw shouldn’t fire. But really wet lumber could be conductive enough or the tip of the nail could have just exited the surface to fire the cartridge. Save yourself the worry and do those cuts – carefully – on bypass.
-- The hump with the stump and the pump!
View Rich's profile (online now)
Rich
6000 posts in 1475 days
#9 posted 09-19-2020 11:26 PM
It s an electrical thing. As long as the nail isn t contacting the metal saw top when the blade hits it, the saw shouldn t fire. But really wet lumber could be conductive enough or the tip of the nail could have just exited the surface to fire the cartridge. Save yourself the worry and do those cuts – carefully – on bypass.
- Madmark2
Then how does the hot dog trip it when it’s sitting on top of a board, that is, insulated from the metal table top?
Madmark2
#10 posted 09-19-2020 11:33 PM
Resistence doesn’t have to be zero, just under 10k or so. Is why wet lumber can be conductive enough to fire it. If a zero ohm contact was the only trip it would never trip on a hotdogs or a finger and it wouldn’t need that complex sensor board to decide when to trip.
Rich
#11 posted 09-19-2020 11:50 PM
Resistence doesn t have to be zero, just under 10k or so.
- Madmark2
Nice try, but I just took my Fluke multimeter out and measured the resistance of a piece of 3/4” alder. Not even megaohms, it was an open circuit. So, a hot dog sitting on top of a board is fully insulated from the table top.
I’ll clue you in. It’s not just a resistive circuit; it’s capacitive as well. Of course, all I have is an MSEE from UW, so what do I know?
CWWoodworking
#12 posted 09-20-2020 12:06 AM
it s capacitive as well.
- Rich
This is the reason I’d be surprised if a nail in a board wouldn’t trigger it.
That and my local dealer said the main reason they send out cartridges is because people hit the blade with a tape measure.
Rich
#13 posted 09-20-2020 12:16 AM
- CWWoodworking
You are exactly correct.
woodbutcherbynight
6319 posts in 3295 days
#14 posted 09-20-2020 05:06 AM
I ll clue you in. It s not just a resistive circuit; it s capacitive as well.
- Rich
+1 Early attempts with only resistance proved to not work well.
- Rich
What happened? You didn’t pay for the rest of the diploma to be spelled out?? Or did they run out of letters???
