Delta saw arbor nut source
Forum topic by spkwms posted 09-11-2020 06:44 AM 753 views 0 times favorited 11 replies Add to Favorites Watch
View spkwms's profile
spkwms
14 posts in 3995 days
09-11-2020 06:44 AM
Topic tags/keywords: tablesaw
I need an arbor nut for a Delta model 36-714 10 inch table saw. The nut part number is A06325. Delta says not available and no recommended replacement. The nut is for a LH tilt RH threaded arbor.
I am open to all suggestions as to where I can get a replacement.
Thank you
11 replies so far
View LittleBlackDuck's profile (online now)
LittleBlackDuck
7858 posts in 2030 days
#1 posted 09-11-2020 09:24 AM
Sounds like my arbor nut issue a few years back… the chances are it’s an acme thread and not readily available over the counter. If Delta can’t help, you’ll be sharpening that pointed stick, moving the TP aside, while looking up that steep hill.
I had a similar issue and started spruiking recycled table saw vendors after the original vendor gave me the no can help sales pitch… After wasting a few months and getting nowhere fast I bit the bullet and took the nut to an engineer and got them to make up a couple for me. The first cost me over $50 but the remaining 3 cost an additional $1.50 (for the three)... Fortunately in my original queries I got a response from another bunny faced with a similar predicament and he was prepared to split the cost for two of them… I deliberately got more than 1 as I had to file a nut down to accomodate my dado set and I’d rather have spares than pay for initial tooling again if required. The fact that I needed a nut to file down and still had the original kept the urgency at bay.
If it is an acme thread it may be a “standard size” that could be canibalised from other branded machinery… I suppose it just depends on how desperate you are. If I amortised the original $50 over the time I spent/wasted searching, it’d work out to be around a few bucks per hour… which I thought was a fair trade… and the cost split between two desperados just sweetened the expense.
View SAndelin's profile
SAndelin
12 posts in 4180 days
#2 posted 09-11-2020 03:23 PM
Here are a couple of threads about the Delta arbor nut. I bought a couple of the brass Uninuts made by a guy who frequents OWWM, and those are very high quality. IIRC those look like ACME threads but are some other industrial thread type that is “close” to the same dimensions of ACME threads, but not the same.
https://www.lumberjocks.com/replies/on/1481333
https://www.lumberjocks.com/topics/249226
Hope that helps.
-- Luck, the point where preparation meets opportunity.
View HerringImpaired's profile
HerringImpaired
103 posts in 918 days
#3 posted 09-11-2020 03:35 PM
Could this be the part. They list a 36-710, maybe the 36-714 is a revision of the 710?
Sorry if no help…. You said the part was no longer carried by Delta, but this source says that is where the parts were obtained….. Check the comments, it sounds like one person claims they replaced your part number with this part.
https://www.ereplacementparts.com/hex-nut-p-86309.html?gclid=Cj0KCQjwwOz6BRCgARIsAKEG4FX948M3ra5pLb2UvslStz3M8GbHrXMkf7M-XOEk57AUsGUF7CD0ZcoaAtw_EALw_wcB
-- "My greatest fear is that upon my demise, my wife will sell my tools for what I said I paid for them."
View 987Ron's profile
987Ron
1955 posts in 525 days
#4 posted 09-11-2020 03:37 PM
The part number for the arbor nut is A06325. The following site says they have it in stock and ship in 5-7 days. Price $5.95 plus shipping. Did not check to see if it is actually available
https://www.appliancepartspros.com/delta-power-equipment-arbor-nut-a06325-ap6619287.html?msclkid=430206c5c6f61377f03c599e5e926007&utm_source=bing&utm_medium=cpc&utm_campaign=Campaign%20%23%20-%20Part%20Numbers&utm_term=Delta%20A06325&utm_content=016
The site is AppliancePartsPros.com never ordered or had any dealings with them. Hope this helps
-- Ron
View ibewjon's profile
ibewjon
2587 posts in 4002 days
#5 posted 09-11-2020 05:22 PM
I have purchased there many times. No problems.
HerringImpaired
#6 posted 09-11-2020 07:07 PM
- 987Ron
Site at the link says out of stock. Maybe the OP got the last one…..
spkwms
#7 posted 09-11-2020 11:09 PM
Checked with AppliancePartsPros and they are out of stock and will not be restocking.
LittleBlackDuck
#8 posted 09-12-2020 12:35 AM
... IIRC those look like ACME threads but are some other industrial thread type that is “close” to the same dimensions of ACME threads, but not the same.
- SAndelin
Thanks SA... I stand (well actually sitting) corrected. I was informed that my nut (arbor) was acme and acme was fabricated and it fit…
Apologies if I mislead anyone… nothing worse than bad advice (and C19... and bad vino)...
View unclearthur's profile
unclearthur
387 posts in 2997 days
#9 posted 09-12-2020 07:44 AM
Hope that helps.
- SAndelin
I bought an arbor nut for a Delta contractor saw from the fellow (Frank S.) in the first thread maybe 5 years ago; worked perfectly.
spkwms
#10 posted 09-24-2020 01:08 AM
I just received from Frank S. a brass arbor nut for my Delta saw. Excellent quality and wok perfect. If anyone is in need of a RH or LH arbor nut for a Delta I would recommend Frank.
View BurlyBob's profile
BurlyBob
9293 posts in 3474 days
#11 posted 09-24-2020 02:59 PM
check Ereplacement parts. I’ve bought several things from there. Prices are ok and shipping is quite fast.
