Equiping a new shop
Forum topic by Beast3 posted 09-08-2020 02:54 PM 377 views 0 times favorited 6 replies Add to Favorites Watch
View Beast3's profile
Beast3
2 posts in 205 days
09-08-2020 02:54 PM
Topic tags/keywords: question bandsaw turning dust collection
I’m starting to equip a new home woodturning shop & I need advice on bandsaws.
I’m considering a Rikon Model 10-324TG 14” open stand bandsaw. The price is good and it’s stated capacity is good for my requirements.
My question concern it having an open stand instead of a cabinet style base.
Is there any advantage or disadvantage to either style?
Anyone have any experience with this Rikon model?
A 2nd question is on dust control & air filters. My shop is in my 2 car garage, approx. 400 sq ft. I’m looking at a ceiling mounted air filter like the Rikon Model 62-400.
Can this type of filter be mounted flat against a wall? With the space the door, lighting, and attic stairs take up there isn’t a lot of open ceil space near where my power tools are used. A cyclone type collector is my other option if I can find a powerful one that fits the budget.
Any advice would be greatly appreciated!
Thanks!
View Loren's profile
10720 posts in 4533 days
#1 posted 09-08-2020 03:14 PM
Band saws vibrate somewhat so heavier ones perform a little better. I don’t imagine in 14” saws a closed based makes such a big difference in vibration though.
Air cleaners perform differently in different locations. Your location may not be ideal for your space, but the machine should still work.
View ChefHDAN's profile
ChefHDAN
1772 posts in 3735 days
#2 posted 09-08-2020 04:09 PM
A 2nd question is on dust control & air filters. My shop is in my 2 car garage, approx. 400 sq ft. I m looking at a ceiling mounted air filter like the Rikon Model 62-400.
Can this type of filter be mounted flat against a wall? With the space the door, lighting, and attic stairs take up there isn t a lot of open ceil space near where my power tools are used. A cyclone type collector is my other option if I can find a powerful one that fits the budget.
Thanks!
- Beast3
An air filter and a dust collector, (cyclone or otherwise) are 2 very different things. I work in my garage and except for times when it’s cold & I’m running an oil filled radiator for heat, my garage door is open. I would suggest that you will get much more use from a DC over an air filter in a new shop. I only recently bought an air filter and only then because it was a silly deal on CL. I will run the filter when doing work with fine dust and after running the leaf blower to clear the shop after I use a broom and the DC to clean up. If you have HVAC in your shop and will always work with the door closed the air filter is a good idea, but I doubt I get much from it when the door is open.
Beast3
2 posts in 205 days
#3 posted 09-09-2020 02:24 PM
Thanks for the info, all your thoughts make good sense & bring up issues I hadn’t thought of. It helps a lot!
View Phil32's profile
Phil32
1146 posts in 789 days
#4 posted 09-09-2020 04:45 PM
A lot of the answers depend on what you’re actually planning to do in your shop. My bandsaw, tablesaw, belt sander, are in my two car garage, and I usually have the door open while doing woodwork. But I’m only doing small, quick tasks to prepare wood for my real hobby – woodcarving. So I don’t have (and probably don’t need) a dust collector. I clean up after each use with a broom.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
View Renegade1LI's profile
Renegade1LI
38 posts in 280 days
#5 posted 09-10-2020 01:55 AM
I have a 3 car shop, I use a harbor freight DC for when I have to make dust inside. I set up a cutting bench behind the garage & use a track saw for most cutting of bulk material, than finish up with table saw. This set up has really minimized dust in the shop, I also rout & sand as much as possible outside, if the weather is bad I work inside with dust collector & air filter. I opted for a 17” with CI wheels & a foot brake, but the rikon looks like a nice saw, has a 4” dust port, most band saws really needs dust pick up at the table anyway. I also use a shop vac for dust collection on small tools, very portable & with a 12’ hose it gives a good amount of flexibility. I also open the doors & blow it out with a cordless blower as needed.
View woodbutcherbynight's profile (online now)
woodbutcherbynight
6318 posts in 3294 days
#6 posted 09-10-2020 03:58 AM
The air filter may be overkill at the immediate moment. But if and when you do install it needs to be in a spot where it draws air away from where you are working. This may be difficult in a shop where the garage doors open overhead. I smoked a cigar and watched the smoke wisp through the air to find the sweet spot in the shop for the air filter. Took a bit.
