cutting large panels
Forum topic by JeffS100 posted 09-04-2020 01:31 PM 283 views 0 times favorited 3 replies Add to Favorites Watch
View JeffS100's profile
JeffS100
1 post in 286 days
09-04-2020 01:31 PM
I am making 8 built in bookshelves for a family room that are 60” tall. I have a 32 in table saw and need to find an accurate way to cut 16 pieces of plywood. I was thinking of using a cross cut sled but I think the pieces will be too big to cut safety. My other thought was to cut one piece with a circular saw (clear the edge with a straight bit in the router), then use the first piece and a flush trimming bit to cut the remaining pieces. Thoughts?
3 replies so far
View northwoodsman's profile
northwoodsman
584 posts in 4863 days
#1 posted 09-04-2020 01:48 PM
Perfect excuse to buy a track saw – splinter free cuts! The router method would work also.
-- NorthWoodsMan
View DrTebi's profile
DrTebi
402 posts in 4384 days
#2 posted 09-04-2020 03:44 PM
I have just been in the same situation. I ended up cutting all plywood slightly oversized with a skill saw with a guide, and then cut each piece to exact size on the table saw with a panel sled. Here is an example of one:
https://www.popularwoodworking.com/woodworking-blogs/panel-cutting-sleds-just-3-bits-wood/
Mine actually has an aluminum angle that holds the fence; it’s mounted with four machine screws into t-nuts. The holes in the aluminum piece are a bit oversized, which allows me to realign the fence when necessary.
This panel sled works great, although it depends a bit on how wide your panels are. On my SawStop PCS I can cut 24” wide panels fairly easily, wider than that can be tricky.
Doing the same (cutting slightly oversized panels) and cleaning up with a guided router should be a good option as well, but will be more elaborate, since you need to re-clamp the guide perfectly square every time.
Good luck!
View SMP's profile
SMP
4148 posts in 1023 days
#3 posted 09-04-2020 04:01 PM
Just get a roller outfeed stand.
