Forum topic by stevejack | posted 09-04-2020 11:45 AM | 473 views | 0 times favorited | 14 replies | ![]() |
This may seem like a dumb question BUT? Are you suppose to install a hack saw blade so it cuts on the Forward stroke or the back stroke? ALSO Best Hacksaw and Best hacksaw blades? |
14 replies so far
#1 posted 09-04-2020 12:14 PM |
Forward stroke, I feel it cuts better that way. Best hacksaw is a sawzaw |
#2 posted 09-04-2020 12:22 PM |
All that are in the stores are preinstalled for a forward stroke. Actually do it the way it works for you on the particular thing you are doing. Maybe even put the blade in with the cutting edge up, whatever works for what you are doing. Joy of woodworking for me is finding the method or tool that helps create my project. -- It's not a mistake it's a design opportunity |
#3 posted 09-04-2020 12:42 PM |
for a hand operated hack saw the blade should be installed to cut on the pull stroke, at least that is what I was taught almost 70 years ago. -- Smitty!!! |
#4 posted 09-04-2020 12:46 PM |
I was taught to make it cut on the push stroke….. -- Heyoka |
#5 posted 09-04-2020 12:49 PM |
Push stroke and Klein is a quality saw. I can see using the pull stroke if cutting over your head though. |
#6 posted 09-04-2020 01:22 PM |
Yes. Push or pull, like a coping saw, whichever is better for whatever you are doing. I have a dewalt high tension that works well. I am still looking for good blades. |
#7 posted 09-04-2020 01:26 PM |
I cut on the forward stroke. The only exception is if I am using one of those cheap frameless blade holders. If you push with that, the blade will inevitably fold up. -- "Join the chorus if you can. It'll make of you an honest man." - I. Anderson |
#8 posted 09-04-2020 03:19 PM |
Pull stroke might work in Japan, but here it cuts on the push. Klein frame is one of the best, and it has a 45 degree position for flush cutting. I have used mine almost daily for forty years as an electrician cutting conduit and unistrut, and it is still in great condition. A cheap saw frame will lead to bad cuts, broken blades, injuries, and swearing. Lennox makes great blades. Remember to use fine blades for thin material, and coarser as the material thickens. Yes, a Milwaukee hackzall battery saw is nice, but too much money for occasional use. |
#9 posted 09-04-2020 04:16 PM |
I have some metal cutting blades for a Rockwell saw with a special end bracket that were made for the automotive exhaust industry. The concept was to cut off old exhaust systems. The blade is about 8 inches long, mid point between the ends is coarse teeth with fine teeth on the end areas. Great for cutting pipe. The tool i.e. Rockwell saw had a special bracket to hand clamp on an old exhaust pipe and cut it off. Never went over well. The exhaust shops preferred their acetylene torches, quicker and easier. I still have one of the saws and a box of the blades. Disposed of the special bracket. -- It's not a mistake it's a design opportunity |
#10 posted 09-04-2020 05:07 PM |
I have a Lenox hacksaw frame that is so far above a cheap hacksaw that my mind was blown when I first used it! |
#11 posted 09-04-2020 05:41 PM |
Lennox blades |
#12 posted 09-04-2020 11:03 PM |
Mid 50’s in highschool I was taught in industrial shop class like woodsmithshop was, cut on the pull. However I fully beleive that what ever works at the time is what to use….larry -- Just a barn cat, now gone to cat heaven. |
#13 posted 09-05-2020 01:32 AM |
Cutting conduit on the pull gets almost nowhere , and not very fast. Personally, I see no time where a pull cut works in a hacksaw. |
#14 posted 09-05-2020 02:50 AM |
I was also taught to install on the pull stroke. I put it in whichever way works best. -- Bruce, Boise, ID |
Forum | Topics |
Woodworking Skill Share
13201 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6348 |
7910 |
32773 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7278 |
1633 |
Focus on the Workspace
2635 |
1272 |
Woodworking Trade & Swap
5418 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9660 |
