Forum topic by Austin6 | posted 09-04-2020 12:16 AM | 488 views | 0 times favorited | 16 replies | ![]() |
I have a couple thousand board feet that are about to be all finished air drying after being milled a while back, is this a pretty good wood for dining tables? I see a lot of walnut and oak dining tables but I never see much sycamore furniture in general. It was beautiful when milled, just curious if y’all have any experience with it and would love to see some furniture y’all have made out of sycamore. Also, it had a very bright red tinge when we milled it, is this common? Any chance that the red will still be there when I uncover it? |
16 replies so far
#1 posted 09-04-2020 12:43 AM |
Sycamore is slightly softer than cherry, but not as soft as soft maple or poplar. Used QS Sycamore for flooring once, and it could be used for table. QS Sycamore is beautiful with a ton of fleck figure. The heartwood tends to look like pink maple to me when kiln dried, air drying might preserve more color? The pink changes to reddish-brown with normal oxidation over time; so wouldn’t expect to find same bright pink when you uncover the piles. Good Luck! -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#2 posted 09-04-2020 12:50 AM |
Every piece of sycamore I have come across has had some pretty soft spots. But I find they make interesting charcuterie boards. |
#3 posted 09-04-2020 01:45 AM |
Sycamore is in the Acer species. It’s not a very common lumber because I’ve heard it’s hard to dry. Good Luck it’s a nice unique opportunity you have there. -- Aj |
#4 posted 09-04-2020 01:51 AM |
Thanks for the heads up on that. I’ll plan to stabilize it with epoxy if that’s the case. Hopefully there isn’t too many soft spots. I have quite the stack of boards to pick through so I’ll try to find the most useable. |
#5 posted 09-04-2020 02:19 AM |
American sycamore is often confused as a maple because of the shape of its leaves but is not in the maple (Acer) genus or family. London Plane tree is the European variety of sycamore and is often planted in as an ornamental in the US. As Klutz said sycamore is a similar hardness to soft maples, though on the low end, so for a table or desk, it might be a little prone to denting so a hard polyurethane finish would be recommended to protect it some. It can be a little boring plane sawn but if it is quarter sawn it can be pretty stunning and definitely worth the risk, IMO. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#6 posted 09-04-2020 04:42 AM |
Sycamore has a Janka hardness of 770, which is less than Cherry, and Soft Maple which both come in at 950. Beyond being sort of soft for furniture requirements a lot in looks will depend on how this Sycamore was cut. Quarter Sawn Sycamore is beautiful, but that said a little of it can go a long way. I see it more often as an accent to other darker woods. While flat sawn Sycamore isn’t real exciting. Either are very easy to work, turn, or tool with anything, hand tool, or power. It is prone to wild movement, so if you cut it, set it out so air can get to all sides afterward, to see if it is going to be stable, or go twisty. A good general read about it here. -- Think safe, be safe |
#7 posted 09-04-2020 05:30 AM |
I stand corrected the Sycamore I’ve read about is the European. Acer pseudoplatanus. -- Aj |
#8 posted 09-04-2020 12:50 PM |
I have built one dinning room table with QS sycamore. It is now about 5 years old. Finish was a General Finishes oil of some kind. The QS really makes the top. Have not had a problem with wood movement. -- It's not a mistake it's a design opportunity |
#9 posted 09-04-2020 01:20 PM |
I love the look of quarter sawn sycamore. I built a computer desk with it three years ago, and it’s holding up well. Parts of the lumber have a lacy look, parts have a lot of swirling grain, and parts have interesting mineral streaks. Photos at this LJ page: Modern Computer Desk . -- Ron Stewart |
#10 posted 09-04-2020 01:25 PM |
I made a sofa table with a quarter sawn sycamore top and I find that it is pretty soft. I love the figure, so I used it any way. -- Bondo Gaposis |
#11 posted 09-04-2020 03:28 PM |
I have read that flat sawn sycamore is unstable. I have mine quarter sawn. I have 2 logs to go to the mill now. Pictured is a ringmaster bowl from a neighborhood sycamore I had sawn. |
#12 posted 09-04-2020 05:25 PM |
Very cool! |
#13 posted 09-04-2020 05:26 PM |
Super neat table. Thanks for sharing! |
#14 posted 09-04-2020 05:27 PM |
That’s awesome. Super cool desk. |
#15 posted 09-04-2020 05:27 PM |
I will definitely be slapping some of mine on the lathe! |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2810 |
Woodcarving
568 |
Scrollsawing
416 |
Joinery
1891 |
Finishing
6338 |
7901 |
32731 |
CNC Woodworking
329 |
Hand Tools
6449 |
Jigs & Fixtures
1803 |
Wood & Lumber
7275 |
1629 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9653 |
