Storm Shelter Leaks
« back to Coffee Lounge forum
Forum topic by siemensgeek posted 08-30-2020 08:48 PM 274 views 0 times favorited 9 replies Add to Favorites Watch
View siemensgeek's profile
siemensgeek
48 posts in 91 days
08-30-2020 08:48 PM
I have a metal underground storm shelter that has developed pin-hole leaks in the wall and ceiling (roof?). I guess that’s what happens when you bury metal for 30+ years. I have been trying to find a coating that I could apply to the inside to seal it. Nearly everything I find on the internet is for concrete or masonry. I found one product for metal roofs, Liquid Rubber Waterproof Sealant. It is meant to go on the top side of a metal roof. Do you think it would work for an inside surface. Does anyone have another suggestion.
I’m trying to get the house in order to sell it so I can buy another house with room for a shop. If I can’t patch the storm shelter I’m thinking about cutting off the top and filling it with dirt.
-- Greg, Amarillo quote - 'Tis dangerous meddling with edge-tools. ~John Tatham, c.1652
9 replies so far
View rcs47's profile
rcs47
217 posts in 4012 days
#1 posted 08-30-2020 09:15 PM
Flex Seal – The guy makes a boat out of screen with the stuff, it must be good ;-)
-- Doug - As my Dad taught me, you're not a cabinet maker until you can hide your mistakes.
View LesB's profile (online now)
LesB
2622 posts in 4326 days
#2 posted 08-30-2020 09:16 PM
If it is rusting through I would question its over all integrity. Besides leaking will ill is cave in on the new owner?
Just from a liability stand point I would fill it in or at a minimum let the new owner make the decision if they want you to fill it or let them deal with the situation.
-- Les B, Oregon
MrUnix
8240 posts in 3082 days
#3 posted 08-30-2020 10:08 PM
POR-15 should work, but as Les mentioned, there is more going on than just a leak that probably needs to be addressed as well.
View CaptainKlutz's profile
CaptainKlutz
3722 posts in 2377 days
#4 posted 08-30-2020 10:43 PM
+1 Question the integrity.
Make note on sales contract of the age, let the inspector find the pinholes (if they even bother), and let new owner decide it’s fate.
IMHO – If you buried it galvanized metal structure 30 years ago, didn’t coat/seal outside and properly channel water away from exterior; then you are already past the life expectancy of 15 years for simple galvanized coated steel in ground contact.
If the outside was sealed and has proper drainage; then pin holes might be due interior condensation and interior sealing could extend the usable lifespan.
Reference: https://www.galvinfo.com/galvinfonotes/
Best Luck!
View sras's profile
sras
5594 posts in 4012 days
#5 posted 08-30-2020 11:31 PM
If the metal is rusting, sealing the inside won’t stop further deterioration.
Is the home more valuable with the shelter? Do most homes have one where you live?
siemensgeek
48 posts in 91 days
#6 posted 08-30-2020 11:44 PM
I’m not the one that buried it. It came with the house when I bought it back in 1979 and the house was built in the late 50’s. Here in the Texas panhandle a storm shelter was a plus, now its a liability. I agree with the risk assessment you guy’s have made I think I would sleep better if it was gone. I don’t have what it would take to get rid of it so I guess I’ll start looking for a contractor to do it for me.
View corelz125's profile
corelz125
1597 posts in 1859 days
#7 posted 08-31-2020 01:10 AM
If you dont want to bury it you could also weld new metal in. Either patch over or cut out the rusted parts.
siemensgeek
48 posts in 91 days
#8 posted 08-31-2020 02:08 AM
Steve
If it was in good shape it would be slightly more valuable but if it is structurally unsafe I think it’s time to scrap it.
siemensgeek
48 posts in 91 days
#9 posted 09-25-2020 03:42 PM
Here is the ‘fix’ for my leaking storm shelter…
Uncover it, cut it off 2’ below grade and fill it with dirt. The contractor is coming today to fill it.
