Router planing/ bits to use
Forum topic by Billiam6725 posted 08-23-2020 12:54 PM 234 views 0 times favorited 3 replies Add to Favorites Watch
View Billiam6725's profile
Billiam6725
1 post in 263 days
08-23-2020 12:54 PM
Topic tags/keywords: end grain planing router bits
I just purchased my router sled for slabs and trying to figure out what bits would be best for planing the end grain pieces! I make a lot of epoxy pieces with wood cookies and want to buy I bit that will leave a smooth surface, any recommendations?
3 replies so far
View Lazyman's profile
Lazyman
6990 posts in 2469 days
#1 posted 08-23-2020 01:15 PM
You can use any wide straight bit but the bottom cleaning bits are designed for the task so will work better. Look for one about 1-1/2” diameter to make the task go faster. Never used one on end grain so I am not sure if a smaller size might work better on those.
View higtron's profile
higtron
278 posts in 3759 days
#2 posted 08-23-2020 01:15 PM
View bigJohninvegas's profile
bigJohninvegas
1001 posts in 2543 days
#3 posted 08-23-2020 09:52 PM
I’m using this one in my router sled.
https://www.toolstoday.com/v-5312-45566.html
I get most of my router bits from this web site, that is if I can not find it locally.
A search for spoilboard turned up all these options listed below.
https://www.toolstoday.com/search?q=spoilboard&page_num=2
And Woodpeckers is offering a router sled now, or they call it a slab flattening mill.
(I’m using a home made sled), But at the bottom of the page they have the Amana bits and a whiteside brand bit.
https://www.woodpeck.com/woodpeckers-slab-flattening-mill.html
The whiteside bit is a 2” diameter, and some of the amana bits get even larger.
I did read on the Woodpecker site that they recommend a 2hp or more router.
So I have that 1-1/2” amana bit in a Dewalt 618 2-1/4 hp router.
I felt 1-1/2” was as big as I should go. But I have a raised panel bit that I use in my router lift that is larger.
So if you go with a 2” plus. Let us know how it works out.
Oh, and what sled did you buy? And what router are you going to use?
-- John
