Forum topic by thediyplan | posted 08-22-2020 03:16 AM | 908 views | 0 times favorited | 8 replies | ![]() |
For most of my DIY woodworking projects are I use construction lumber like 2×4s, 4×4s, 1×4s…. I try to select straight pieces at the store, but when I bring them home and leave them in a garage for a few days, some 2×4s would warp and some will not. Why? -- Viktor - Plans at https://thediyplan.com/ |
8 replies so far
#1 posted 08-22-2020 03:35 AM |
Because they are not dry. When your construction lumber loses moisture it has to change its shape. Good Luck -- Aj |
#2 posted 08-22-2020 03:46 AM |
With construction lumber from the BORG, warpage is caused by : Looking at it wrong |
#3 posted 08-22-2020 03:54 AM |
Something I’ve learned about lifts of Douglas fir. The best boards are usually on top or the bottom unfortunately the ones on the bottom are scarred badly from fork lifts. And the one on top are warped from direct sun light drying them unevenly. :( Good Luck -- Aj |
#4 posted 08-22-2020 06:13 AM |
I’m surprised more haven’t responded. When I buy boards I not only look at straightness, but also look at the end grain pattern on both ends. We have five sawmills in our area. This is typically want happens to most construction lumber. Most sawmills will leave the logs brought in to them out in the yard for a while before processing. During this time they have the logs sprayed and saturated down with water to soften the bark before running through the mill. Then the logs are run through for debarking. Then go through a cutting process to cut the logs down to size. Then a planning process to size. Then separate the lumber by grade. With some sawmills, construction lumber is stacked outside and air dried after milled, then bundled and wrapped for shipping once they get to a certain moisture % (not all of them). We have a couple sawmills out here that will kiln dry the lumber to bring down the moisture content (to speed up the drying process time), before restacking-bundling-wrapping and shipping. There’s also sawmills out here that once the lumber is cut-bundled-wrapped, they shipped directly to the distribution centers and stores without even being dried (air or kiln). The stores will say this stuff is ‘right from the sawmill’. I’ve hauled out of each of these locations for 19 yrs. The construction lumber at Menards, Lowes, Home Depot, Builders Square and many other lumber yards I feel aren’t really even air dried. Even treated lumber is treated green and shipped with no real drying period. The only air drying most construction lumber see is while being shipping and sitting in distribution centers and stores. Usually the cheapest priced lumber because they have no actual drying expense. So with using construction lumber expect more wood movement in the wood. look at the end grain pattern on each end. Read up on some of the wood books that explain ‘shopping for lumber’ and ‘wood movement’. Read-up on Riftsawn, Quartersawn, Plainsawn-Flatsawn, Heartwood, Sapwood, Pith. Plainsawn-Flatsawn is more prone to cup. Every type of warp has a name (Bow, Crook, Cup, or Twist). Read-up on wood movement to understand more on wood movement. |
#5 posted 08-22-2020 08:15 AM |
Chapters in this “Wood Handbook,” pretty much explain everything you might want to know & more than any of us really need to know. https://www.fpl.fs.fed.us/products/publications/several_pubs.php?grouping_id=100&header_id=p Chapter 6 explains lot about both hard & softwood processing & grading systems: Nice free reference might want to save & refer back to different chapters as needed. -- Bill |
#6 posted 08-22-2020 11:15 AM |
You can avoid warped lumber fairly easily by careful selection. Here are the basic things I look for when selecting lumber (roughly in order of importance):
-- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#7 posted 08-22-2020 11:30 AM |
@WoodenDreams Thanks for that explanation. I can remember each time I passed a saw mill they had an array of sprinklers keeping all the logs wet. |
#8 posted 08-22-2020 12:12 PM |
The sprinklers are to mostly to keep logs from starting to split at the ends as they wait to be milled. Saw and plywood mills often have to buy logs when they can so that they have inventory when weather or other factors slow down supply and keeping the ends wet will prevent most degradation while the logs sit on the lot. Since they still have the bark on them, this won’t add much moisture to the logs. Plus, when cut, logs usually have the most moisture they are ever going to have. During a logging and milling course I took in college, we toured a bunch of saw and plywood mills. A few of them even stored their logs in ponds. It was a long time ago so I don’t remember for sure but that may have mostly been plywood mills that were going to soak the logs in hot water 8 or more hours anyway to make them easier to peel. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
Forum | Topics |
Woodworking Skill Share
13208 |
Woodturning
2815 |
Woodcarving
570 |
Scrollsawing
416 |
Joinery
1900 |
Finishing
6354 |
7914 |
32792 |
CNC Woodworking
330 |
Hand Tools
6457 |
Jigs & Fixtures
1809 |
Wood & Lumber
7285 |
1634 |
Focus on the Workspace
2637 |
1272 |
Woodworking Trade & Swap
5421 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9664 |
