Need parts for Ram Bandsaw
Forum topic by Woodshoprealtor posted 08-13-2020 04:26 PM 192 views 0 times favorited 1 reply Add to Favorites Watch
View Woodshoprealtor's profile
Woodshoprealtor
1 post in 43 days
08-13-2020 04:26 PM
Topic tags/keywords: bandsaw parts ram machinery
I just purchased a used Ram Machinery band saw. It is a 14” model 0067. It was dropped during loading and broke the mounts that hold the table. Any idea where I can get some replacements? I’m so bummed I haven’t even got to use it yet. Thanks.
1 reply so far
View CaptainKlutz's profile
CaptainKlutz
3604 posts in 2347 days
#1 posted 08-13-2020 06:17 PM
Welcome to Lumberjocks!
You just learned the 1st rule when moving any band saw,
Remove the heavy cast iron table before transportation!
Guessing you have broken trunions? The wimpy cast metal trunion brackets are barely strong enough to hold the table, much less hold a table during transport. Can not tell you home many times I see used band saws for saw with broken trunions.
Regardless, Good news:
Most the clone 14” bandsaws made in Taiwan use the same delta trunion design:
Generic replacements are available on fleabay and Amazon, usually listed for Delta, Ridgid or Central Machinery Band saws.
Remove yours and check the mounting tabs, and angle indicator location; and you will be able to sort out the minor differences between models.
If you need different part, need to post some pictures of broken stuff so we can help.
Best Luck!
