Yates American J-180 Planer
Forum topic by motion posted 08-13-2020 09:42 AM 160 views 0 times favorited 1 reply Add to Favorites Watch
View motion's profile
motion
11 posts in 709 days
08-13-2020 09:42 AM
Has any member changed the cutter head bearings on a J-180 planer? In order to do so the rotor needs to be removed from the cutter head shaft, the question is is the rotor pressed on and how best to remove it? I can remove the entire assembly i.e. cutter head, rotor, bearings/holders. the bearings don’t feel bad but as long as I’m removing the assembly I might as well change them. I taking it apart because the PO turned it over and cracked the outfeed bed webbing and needs to be welded. Thanks in advance.
1 reply so far
View GrantA's profile
GrantA
2856 posts in 2260 days
#1 posted 08-13-2020 10:06 AM
Head over to owwm.org and so some searching /make a post
