What do you use to shim tabletop jointer table?
Forum topic by SMP posted 08-12-2020 01:30 AM 278 views 0 times favorited 4 replies Add to Favorites Watch
View SMP's profile
SMP
2447 posts in 754 days
08-12-2020 01:30 AM
I have a Delta 6” tabletop jointer and last time I used it I gave up because it was making my boards worse. So Checked the tables and they were pretty bad off. I googled and found some people saying to use beer cans etc. Was curious what fellow LJers have used that have done this.
View bilyo's profile
bilyo
1161 posts in 1951 days
#1 posted 08-12-2020 03:00 AM
Yes. You can use any thin metal like beer cans, aluminum flashing, or you can buy brass shim stock of varying thicknesses.
View CaptainKlutz's profile
CaptainKlutz
3589 posts in 2342 days
#2 posted 08-12-2020 05:27 AM
Lot of choices.
Brass assortments on Amazon
Need less material and cheaper solution?
By a cheap feeler gauge and use what ever tabs you need, then save rest for next project.
Cheers!
View SMP's profile
SMP
#3 posted 08-12-2020 01:05 PM
Thanks! I am heading to HF anyways so may just pickup one of those cheap feeler gauges.
View therealSteveN's profile
therealSteveN
6245 posts in 1422 days
#4 posted 08-12-2020 02:35 PM
If you cut them open, you will see a variance between brands of pop, and beer cans. Coors has had some of the thinnest cans made for years. A lot of off brand pops seem to have the heavyweight title. A HF feeler does take you through the entire cycle though.
-- Think safe, be safe
