Do you own and use an Universal Six-Sided Angle Measuring Locator?
Guess where the outlets go?
News flash! They ve invented the stick! With just a stick I can accurately cut outlet openings.
- You put the end of the stick at the edge of the outlet.
- Then place your thumbnail on the stick at the edge of the last piece.
- Without moving your thumb, go to the sheet of rock and place your thumb holding the stick tight to the edge.
- Pull your knife out with your other hand.
- Hold the knife at the end of the stick and cut there.
- Repeat as required.
The more things change, the more things stay the same.
LOL
- Madmark2
Is this stick yellow with markings along one side?Guess where the outlets go?
- Madmark2
Only the domesticated ones…..Is this stick yellow with markings along one side?
- LeeRoyMan
Are you saying there's only one way to skin a cat…...........your way.A piece of string also works. They built the pyramids with strings and water.
- Madmark2
Not everyone knows it all like you and some would like to skin a cat differently.Guess where the outlets go?
LOL
- Madmark2
I don't see any string so I doubt its Madmark approved.Got mine today.
Should work fine for the next task at hand. It will pay for itself, just in time alone, on this first job.
- LeeRoyMan
Lol, as long as they keep printing phony money out of thin air…..........................Talk about inflation… was $14.88 a year ago. larry
https://www.worthbuystore.com/product/universal-angle-ruler/
- ohtimberwolf
