Show me your kiln.
Forum topic by Robert posted 08-09-2020 03:10 PM 363 views 0 times favorited 10 replies Add to Favorites Watch
View Robert's profile
Robert
3936 posts in 2329 days
08-09-2020 03:10 PM
I’m mostly interested in what you used for heaters, dehumidiers, fans,etc.
Is insulation necessary? It doesn’t get too cold where but I thought insulation would help regulate the temp.
Seems most of the info I’ve seen on LJ is solar.
I do not want to build a solar kiln.
Please do not show me your solar kiln. Thx guys!
10 replies so far
View therealSteveN's profile
therealSteveN
6245 posts in 1422 days
#1 posted 08-09-2020 06:39 PM
On a Goofle search instead of Kiln, put dehumidification kiln, the world is your oyster with the proper word use on a search. Almost all of the links under kiln only are solar
-- Think safe, be safe
View ibewjon's profile
ibewjon
1937 posts in 3641 days
#2 posted 08-09-2020 08:44 PM
A dehumidifier under a plastic sheet over the stickers wood works for me. Run a drain hose out of the enclosure, don’t use the dehumidifier storage tank. I ran some wires out to connect to my mini ligno moisture meter. The dehumidifier provides the heat, and a small fan helps circulation. I let the stacks air dry inside a garage for about a year first, I am not in a rush as I have plenty of lumber. The ‘kiln’ is for final drying.
View MPython's profile
MPython
298 posts in 660 days
#3 posted 08-10-2020 01:10 PM
Not what you asked for, but this might be off interest to some here. I learned this from a good friend who is a high-enbd plane maker. It’s called a “finishing kiln” for small wood parts. I purchased some Gabon ebony for saw handles from a reputable dealer. It was represented to have been air dried for fifteen years. When it arrived it was at 18% moisture content – way too high to be worked successfully. I built this simple finishing kiln and dried it to 8% in about three months with no warping or checking.
It’s simply a chimney made of 1/4” plywood and some 1 1/2” X 1 1/2” X 60” pine for legs, open at the top and bottom. It has a light socket at the bottom with an incandescent light bulb and a switch for convenience. The light bulb generates a little heat which, in turn creates a gentle convection up the chimney. The warmed air passes by the wood blanks that rest on a wire rack about halfway up the chimney.
I just turned on the light, shut the door and left it in the corner of my shop, checking the M/C every few days. It took less time than I expected to get the ebony to a workable moisture level. Not fancy and probably not applicable to large boards, but it was perfect for the small pieces I needed.
View tomsteve's profile
tomsteve
1064 posts in 2067 days
#4 posted 08-10-2020 01:28 PM
On a Goofle search …...
- therealSteveN
. does goofle get better results when searchin???
Robert
#5 posted 08-10-2020 01:30 PM
@theealSteveN
- therealSteveN
Thanks for the info.
I have several 100 BF of walnut and poplar that has been air drying in a shed for a little over a year. In my area the equilibrium MC is anywhere from 12-15%, so I don’t need to bring it down that much.
After looking at a couple of the articles available, I’ve decided maybe all I need is a plastic tent. with a dehumidifier and small fan.
I’ve treated all the lumber with Boramate, so I shouldn’t be worried about killing bugs.
Does this sound feasible? My thinking is the heat generated by the DH combined with the moisture reduction should bring it down to 8% fairly rapidly.
What do you think?
ibewjon
#6 posted 08-10-2020 01:48 PM
That is what I do. Just don’t try to dry it down too fast.
therealSteveN
#7 posted 08-10-2020 03:34 PM
- therealSteveN
- tomsteve
Probably knot. :-)
therealSteveN
#8 posted 08-10-2020 03:38 PM
That is what I do. Just don t try to dry it down too fast.
- ibewjon
Yes you want to discourage fast drying.
The only real problem I have seen with the plastic tent methods, it there is no easy way to control the heat/temp. A fan will lower, but often just eliminate enough heat to work, so if you use a fan, you need to do it with some type of thermostat. Time you get everything in place you coulda built a kiln…..
ibewjon
#9 posted 08-10-2020 04:53 PM
If I had a place for a permanent kiln, that would be great. But I can roll the plastic and store it in a garbage bag, and use the fan for other things. I saw a nice solar kiln in central Illinois, but I don’t have the yard space. I did buy some nice sassafras lumber from the man, along with a flat master sander.
Robert
#10 posted 08-10-2020 05:10 PM
- therealSteveN
How about rigid foam?
