Metal Detector recommendations?
Forum topic by ChefHDAN posted 08-05-2020 12:50 PM 312 views 0 times favorited 9 replies Add to Favorites Watch
View ChefHDAN's profile
ChefHDAN
1803 posts in 3903 days
08-05-2020 12:50 PM
I’ve been searching through the site and looking at items and reviews. I have a new customer wanting items from reclaimed barn wood etc. & need to finally go ahead and get one. Prices have a huge range, looking to my LJ Brethren for whats working well for you and/or what you wish you had bought instead.
Many thanks!
9 replies so far
View MrUnix's profile
MrUnix
8513 posts in 3253 days
#1 posted 08-05-2020 05:25 PM
I only have experience with the HF handheld, which I also use as a pinpointer when I’m out digging stuff up with the big detector. It has never let me down yet and I’ve had it for going on 10 years now. I think I got mine with a “super coupon” for $9.99.
ChefHDAN
#2 posted 08-05-2020 05:32 PM
Thanks Brad, I had not even considered HF, but we recently got a store and ill take the excuse to go look at what they have, I value your opinion!
View ibewjon's profile
ibewjon
2348 posts in 3847 days
#3 posted 08-05-2020 06:09 PM
I have a Little Wizard, about 4” wide, and a Wizard 4, about 12”, for larger areas. Both have served me well. I believe the Little Wizard was purchased at Harbor Freight.
View Kazooman's profile
Kazooman
1540 posts in 3006 days
#4 posted 08-05-2020 07:24 PM
I had the HF detector that Brad mentioned. It worked fine for a few years and quit. The price was right so I went back to the store and they do not stock it any more. Staff had no reason to offer. I have looked every time I stop in. It seems to be available on line and might be in your store.
That prompts me to go over to HF again for another look.
MrUnix
#5 posted 08-05-2020 08:16 PM
- Kazooman
The web-page says “In Store Only”, which is kind of weird – sure would think they could ship it easily. But maybe you could speak with a manager or someone and have them order it to be delivered to your local store.
I do have one tip though – since I used mine for pinpointing in dirt and mud, I sealed the antenna part with that ‘liquid electrical tape’ stuff – basically just liquid plastic that hardens when exposed to air, so I guess the stuff used to coat tool handles would work as well. Anyway, it keeps out any dirt and moisture and seems to make it a bit more robust.
Kazooman
#6 posted 08-05-2020 09:07 PM
Well, I was curious enough to go over to HF. It is pretty close. They did not have the little metal detector. I Googled it up on my phone to show the guy in the store. I noticed that not only did it say “in store only” it also said “clearance”. We checked on the shelves and he checked in the back where they have a few odds and ends in a clearance rack. No dice.
That led to me picking up the “big brother” version that I have looked at several times and it is now sitting on the bench in my shop.
Note added later: I popped in a battery and the unit seems to work just fine. There is one issue that is not ideal. The detector comes with a preset sensitivity that apparently is meant to be OK for scanning people for security reasons (concealed switchblades, box cutters, hand guns, grenades and the like, I assume). There is a button to reduce the sensitivity by about 50%. In order to adjust the sensitivity for other purposes you need to “slide the rubber handle cover off” and then adjust with a small screwdriver followed by replacing the handle. Not the most user friendly system. I will have to experiment with some things like small nails embedded in a piece of wood to see what setting works for me. The much cheaper small version has sensitivity adjustment potentiometer knob on it.
One final note: the detector came with a cardboard tag attached instructing me to always wear ANSI approved safety glasses when operating the unit. I suppose that if you were waving the wand around like crazy looking for hidden metal you might poke someone (including yourself) in the eye. Let’s be safe out there!
View northwoodsman's profile
northwoodsman
525 posts in 4800 days
#7 posted 08-05-2020 11:05 PM
I have the Little Wizard II. Probably bought it at Woodcraft, Rockler, or one of the DIY home centers. I seldom to remember to use it. It’s found a couple staples. I guess I get lucky and purchase clean wood.
-- NorthWoodsMan
View Madmark2's profile
Madmark2
2498 posts in 1642 days
#8 posted 08-06-2020 02:09 AM
I’ve had two Little Wizards and they were just so-so. The sensitivity control is hard to adjust and seems to only have two settings, off and on.
-- The hump with the stump and the pump!
View TheBeej418's profile
TheBeej418
12 posts in 456 days
#9 posted 08-06-2020 03:10 AM
- Kazooman
I have the Centech from HF as well and it’s saved me a few sets of planer blades. There’s always going to be something better but this one seems to do just fine.
-- Brian, Nashville, TN
