When you accidentally buy 5/8” drywall for a repair, but needed 1/2” and Home Depot is closed
« back to Hand Tools forum
Forum topic by SMP posted 08-05-2020 02:47 AM 899 views 0 times favorited 8 replies Add to Favorites Watch
View SMP's profile
SMP
2447 posts in 754 days
08-05-2020 02:47 AM
Needed 1/2”, bought 5/8 by mistake, HD is closed and need to get some mud on to dry overnight. I figured I could set my old Stanley 78 to 1/8” depth, flipped the spur cutter out and cut a rabbet in about a minute, lol.
8 replies so far
View sansoo22's profile
sansoo22
1125 posts in 502 days
#1 posted 08-05-2020 02:53 AM
“If the women don’t find you handsome, they should at least find you handy” – Red Green
In all seriousness though that is quite an ingenious solution.
View Axis39's profile
Axis39
338 posts in 445 days
#2 posted 08-05-2020 01:44 PM
Knowing what drywall does to razor blades, that makes me cringe… LOL
But, I still live by the creed – Improvise, Adapt and Overcome! So, good on ya!
-- John F. SoCal transplant, chewer uppper of good wood
View GrantA's profile
GrantA
2852 posts in 2256 days
#3 posted 08-05-2020 02:10 PM
I was thinking the same Axis, I’m sure SMP will spend some time cleaning the plane now :-)
View Jared_S's profile (online now)
Jared_S
396 posts in 807 days
#4 posted 08-05-2020 03:11 PM
If it works.. but I’d be worried about cracking later with no paper on the back side there
Why not just go back the next day get 1/2” and tape with some 20 or 45 minute mud?
View LesB's profile
LesB
2599 posts in 4291 days
#5 posted 08-05-2020 10:24 PM
That is a bad idea. If you remove the paper from either side you reduce the integrity and strength of the sheetrock. It can easily crack and crumble without that support.
Without knowing what the particular application is it would probably be better to shave 1/8” off the structure (I assume wood studs) you are fastening it to than modifying the sheet rock.
-- Les B, Oregon
View ibewjon's profile
ibewjon
1937 posts in 3641 days
#6 posted 08-05-2020 10:39 PM
Taking the paper off the back creates a perfect weakness for a crack. I would have scraped the stud.
View Andybb's profile
Andybb
2831 posts in 1452 days
#7 posted 08-06-2020 12:43 AM
If it’s a small patch in an out of the way place you should be good until your kids inherit the house then it’ll be their problem.
-- Andy - Seattle USA
View Underdog's profile
Underdog
1523 posts in 2884 days
#8 posted 08-06-2020 01:13 AM
Yep. I did that the other day. I measured the thickness on the edge instead of the end. Thing is, apparently they taper the edge for tape and mud. I also found out the hard way that you shouldn’t predrill the holes for the same reason you leave the paper on… And don’t use regular mud to try to seal cracks. Now I get to do it over… ...at some point.
down the road…..
a piece…
a few months…
or..
...years from now.
-- Jim, Georgia, USA
