MDF mortise
Forum topic by ed23 posted 08-02-2020 11:25 PM 260 views 0 times favorited 4 replies Add to Favorites Watch
View ed23's profile
ed23
45 posts in 79 days
08-02-2020 11:25 PM
I mortised these concealed hinges into 5/8 mfd leaving an 1/8 material and its so fibrous in the hole. I could use my fingernail and go thru the board. I realize the hinge will be in there but should I coat the hole with something in case moisture gets in there?
View Aj2's profile (online now)
Aj2
3325 posts in 2646 days
#1 posted 08-03-2020 01:08 AM
Why would moisture get in there.
I would focus on your screw installing that’s going to be tricky.
Good Luck
-- Aj
View Rich's profile
Rich
5868 posts in 1437 days
#2 posted 08-03-2020 05:21 AM
No need to deal with that. Screws hold well in the face of MDF and that will keep the hinge secure.
View CaptainKlutz's profile
CaptainKlutz
3589 posts in 2342 days
#3 posted 08-03-2020 06:24 AM
BTDTGTTS
Thought I was being smart and poured some shellac into the fuzzy holes, and when I tried to pour out the excess; there was none. It was dripping out bottom onto the bench. Normally fill MDF edges/pores with dry wall compound and use BIN primer. The shellac around hole left a noticeable texture variation across the panel. Ended up needing to seal the entire door face with 2nd coat of primer and sand down the first one to even out the surface texture. #IAMAKLUTZ
Better plan is spray primer on all surfaces at same time to avoid the bleed through.
YMMV
View AlaskaGuy's profile (online now)
AlaskaGuy
5984 posts in 3157 days
#4 posted 08-03-2020 06:55 AM
With MDf and melamine board I always use the plastic dowels.
