I'm building a live edge patio table. First timer with woodworking so learning as I go. I've viewed several YouTubes and read many articles - none provide any detail on the length of the 'insert' I should use to attach my table legs (28" U shaped with 4 holes).
Should I use 20mm or 30mm length? The slab patio table is 22" x 6'. Table depth is about 1.50". Appreciate some advice. Thanks.
I know what the blue jay is talking about. But I cannot tell because I have a minimum fee for using my Psychic abilities.
And my crystal ball is in the shop getting fixed.
Thank you Dave for your response. I will get the maximum diameter bolt - awaiting delivery of table legs and have the max diameter question into the vendor. U shaped table leg pic.
Let me reframe my question and hopefully provide some clarity. Sanding is complete.
The final slab table depth is 1.5", not 1.75" as originally stated.
So based upon your answer, I should probably drill to 1" depth, and therefore the inserts to be purchased should be 1" length also. Thanks again!
the metal frame you show that you will be using for legs
will require the metal threaded inserts that match the size of
bolts you will be using. you need a metal insert - not a wood insert.
(and you will be needing 4 inserts per leg).
you will also need the appropriate size flat washer between the bolt head and leg frame.
the length of the threaded bolt should be "about" the length of the insert.
some people thrive on custom installation tools ~ I personally just use a bolt.
if you have a project that would benefit from a more beefier mounting, two inserts
can be fitted into the wood, one on top of the other. (strictly a personal judgement call).
looking forward to seeing your finished project.
this is how your installed leg frame should look.
the inserts should be available at your local Box Store.
use flat washers - not lock washers.
do not over-tighten the bolts. just snugged down firmly to allow
the wood to move with the seasons.
If this is an outdoor setting exposed to elements (especially sun), you can expect some warping or cupping to occur.
I've seen many guys attach angle iron crosswise to the bottom to counteract this, usually a groove being cut that one edge of the angle goes into. Holes elongated to allow for movement, attached with lag bolts.
Speaking of which, why won't lag bolts will do the same thing as the inserts with a lot less hassle?
If it were me I would try large diameter wood screws like #12 (ish). With the 1.5" thickness would use 1" or 1.25" length and be careful of depth of pilot hole.
Small diameter lag bolts also would work.
The inserts like John Smith are also an alternative. They can be found online at Amazon, link below:
WS or lags would be much easier. I have not used these inserts but they look useful.
You may already know this but pilot hole diameter is important. This information is online, do a search for "pilot hole diameters for wood screws
On second thought maybe use machine screws with a pan head and washers is better than wood screws. Machine screws have threads the full length of the Shank.
DG
Send me a link to your legs you ordered. It can be by private message or here on the LJ site.
I wouldn't waste my time on threaded inserts unless this is something you want to be able to break down when you move. Washer head screws will work just fine, or just screws with washers.
Machine screws are intended to be used with threaded connectors like a threaded insert or a nut. Perhaps you were thinking of sheet metal screws, which would be ideal to use in this application along with washers.
Good advice overall in your post however. Thanks for sharing.
I want to correct my comment saying to use "MACHINE SCREWS". I meant "Sheet Metal" screws. Which have a pointed end and threads full shank length.
DG
Bluejay,
DG
Lag bolts and some washers.
Those inserts John suggested are good but I've had them lose their hold I probably didn't drill the right hole or something. I'm usually pretty good about my pilot holes . So I label them tricky.
1 inch lag bolts are pretty hard to mess up.
Good Luck
Thanks everyone for the information, including recommendations for alternatives. As a newbie, I watched many YouTubes, which recommended inserts over screws to avoid loosening over time. I thought this was a standard practice, hence my question to you all! The table, when done, will be used outdoors with no intention of disassembly at anytime. Lag bolts sound good - and yes, I'm familiar with criticality of the pilot hole diameter. Will be installing C channels to prevent cupping and warping.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
