square nut recess how
« back to Woodturning forum
Forum topic by Karda posted 08-01-2020 06:06 AM 333 views 0 times favorited 14 replies Add to Favorites Watch
View Karda's profile
Karda
2348 posts in 1353 days
08-01-2020 06:06 AM
Hi, I need a new plane knob, But the screw is a square nut recessed in the top of the knob. You turn the knob to tighten it and the knob cracks. How do I make the mortise and when do i do in the turning sequence. thanks Mike
14 replies so far
View Lazyman's profile
Lazyman
5623 posts in 2187 days
#1 posted 08-01-2020 11:43 AM
I think that I would do it before you turn it. While the blank is square, you can more easily clamp in in a vise while you work on the the recess. Here is how I would do it.
  • With a Forstner bit, drill a hole the same diameter as the square nut a little deeper than the thickness of the nut
  • Drill the center hole for the bolt all the way through the block
  • Place the nut over the wide hole and thread the bolt into it from the bottom (use a washer on the bottom), making sure that the sides of nut are centered on the hole cut with the Forstner
  • Tighten the bolt just enough so that the nut compresses the grain. This is to mark the size of the square hole you need to cut
  • Mark the edges of the square with a knife and use a chisel to cut out the corners of the square.
  • Mount the blank on the lathe and shape as desired making sure that you don’t remove too much wood from the end so that the nuts will stay recessed.
View John Smith's profile (online now)
John Smith
2501 posts in 962 days
#2 posted 08-01-2020 12:24 PM
this looks like an “aftermarket” alteration to me.
for whatever unknown reason, someone removed the factory screw
and hand cut the square hole with a pocket knife and chisel.
if it were mine, I would go back to the round factory screw and forget
trying to make a square hole.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View Nubsnstubs's profile
Nubsnstubs
1727 posts in 2529 days
#3 posted 08-01-2020 03:05 PM
Mike, John is probably right. If that were a factory square hole, it would probably be painted and not raw wood like you are showing us…........ Jerry (in Tucson)
View bigJohninvegas's profile
bigJohninvegas
788 posts in 2261 days
#4 posted 08-01-2020 05:15 PM
Karda, I think everyone is right here. Nathan is right on with how I would make the square hole too.
But as John pointed out. It was most likely a round fastener from the factory.
What brand and model hand plane is it?
The little brass nut on a Stanley plane is pretty common, and cheap.
-- John
Karda
#5 posted 08-01-2020 05:31 PM
I checked ebay and my knob is aftermarket piece. I think i’ll stick with my broom stick. To get a knob or even the proper nut would cost more than I paid for the plane. One guy has a nut reasonable then 5.15 for a part that weighs maybe 10grams. My plane is a MF814 it a V line plane so not that good to begin with
Karda
#6 posted 08-01-2020 05:40 PM
thanks John I check my Stanley and see if it fits
Karda
#7 posted 08-01-2020 06:18 PM
I checked the nut on my Stanley thanks #5 and it fit like it was made for it, thanks
bigJohninvegas
#8 posted 08-01-2020 06:28 PM
You can turn a new knob. And now that you know the Stanley part fits. Yard sale junk planes are everywhere. Most of my planes have a part or two from others. Frankenstein plane. Lol.
Good luck.
-- John
View SMP's profile
SMP
2233 posts in 705 days
#9 posted 08-01-2020 10:22 PM
Good luck.
- bigJohninvegas
Yep, from buying various “parts” planes from CL and antique stores to put together planes, I have a drawer of various parts now.
Karda
#10 posted 08-01-2020 11:22 PM
I seldom see planes on my craigs list, the only planes I know of are so rusty you can’t tell the brand and i don’t know planes well so I can’t tell by looks alone. I know there is a dunlop a handyman and a wards or ward master not sure and they are priced to high. iam going to have a look though
View therealSteveN's profile
therealSteveN
5901 posts in 1373 days
#11 posted 08-02-2020 04:40 AM
Ahhhhhhggg so this is how Frankenplanes were invented…..
Everyone who has more than 5 hand planes probably has a little parts box. Get 5 or 6 people like that together, you might end up with 20 new, but old, planes happening.
-- Think safe, be safe
Karda
#12 posted 08-03-2020 01:57 AM
I just saw a nut and rod foe a stanley #7 knob will that nut fit a #5
View corelz125's profile
corelz125
1394 posts in 1775 days
#13 posted 08-03-2020 02:07 AM
I have had some Stanley parts not fit Miller’s Falls parts. I’m not sure what types work. Kenny might know more about it.
Karda
#14 posted 08-03-2020 05:04 AM
I have A Stanley #3 and a #5 and the nuts fit the MF knob rod, I was wondering if the #7 nut would fit as well
