CNC used for this project?
Forum topic by Db2020 posted 07-22-2020 01:18 AM 704 views 0 times favorited 15 replies Add to Favorites Watch
View Db2020's profile
Db2020
3 posts in 549 days
07-22-2020 01:18 AM
Topic tags/keywords: cnc wood bending
I wanted to make a similar design however I am new to woodworking and I was stuck in what was used for the front. Is this a wood bending technique or is this CNC? I ant figured out how they got such a big piece of wood to bend as one piece
15 replies so far
View John Smith's profile
John Smith
3033 posts in 1498 days
#1 posted 07-22-2020 01:25 AM
welcome to the forum.
no CNC involved – just simple bent lamination.
easy to do – just glue a few pieces of thin wood together in a form
and cut to shape after it sets.
YouTube: steam bending and lamination bending.
-- I am a painter: that's what I do, I like to paint things. --
View Desert_Woodworker's profile
Desert_Woodworker
8778 posts in 2550 days
#2 posted 07-22-2020 01:56 AM
- John Smith
+1 Look into steam bendind
-- Desert_Woodworker
View SMP's profile
SMP
5071 posts in 1241 days
#3 posted 07-22-2020 02:42 AM
You could probably do that with hot pipe bending too. If you have a propane torch and scrap metal pipe you already have what you need, if only doing one that probably cheaper and easier.
Db2020
3 posts in 549 days
#4 posted 07-22-2020 06:35 AM
Thanks for the advice. I was confused since it looked like it was one piece and plywood which I did t know it could bend this way thanks!
View Tony1212's profile
Tony1212
658 posts in 3070 days
#5 posted 07-22-2020 12:58 PM
- Db2020
What looks like plywood is actually two thin pieces glued together over a form. It’s called bent lamination.
It just so happens that I have a youtube video on how I did it for a bowarm morris chair.
-- Tony, SW Chicago Suburbs
View LeeRoyMan's profile
LeeRoyMan
2386 posts in 1063 days
#6 posted 07-22-2020 01:35 PM
Could be 3/8” Bender Board or sometimes called wiggle wood, or bendable plywood.
John Smith
#7 posted 07-22-2020 03:05 PM
DB – what tools do you have or have access to ?
you don’t have to make a complicated steam box like so many show
on YouTube, etc. many folks use a piece of PVC pipe and a steam source.
whatever you have access to and what works for you.
I used my electric cooker to bend some 1/4” red oak which served my needs.
softer woods will bend much easier than hardwoods.
View Dark_Lightning's profile
Dark_Lightning
5010 posts in 4445 days
#8 posted 07-22-2020 03:20 PM
^ Wow, the methods I learn here!
-- Steven.......Random Orbital Nailer
View splintergroup's profile
splintergroup
6354 posts in 2558 days
#9 posted 07-22-2020 05:41 PM
Love the simplicity of that John!
Problem is how to prepare the bacon while waiting for the wood to soften…
LeeRoyMan
#10 posted 07-22-2020 05:58 PM
There is also a product called 1/8” bending birch.
Below you can see how easily it forms a bend
You take 3 or 4 layers, put glue in between each layer, then clamp it all tight to a form.
Or you can make a 2 part form and sandwich it in the middle.
Clamp the block together.
John Smith
#11 posted 07-22-2020 06:52 PM
DB – understand that when steaming some “plywoods”, they could actually delaminate.
only solid wood should be steamed, in my opinion.
if you have access to 1/6” thick wood, laminating to shape with glue and clamps
would be the most recommended.
LeeRoyMan
#12 posted 07-22-2020 06:56 PM
- John Smith
John, are you inferring that I meant to steam bend these 1/8 strips ?
The 1/8”, I mentioned above, is perfect for laminating together, no need for 1/16th
Have you ever used the 1/8” birch?
John Smith
#13 posted 07-22-2020 07:57 PM
LeeRoy – no not your post. (of which I agree with wholeheartedly).
in post #4, the O/P is referring to the project being made out of plywood.
then we started talking about steam bending.
I did not want the O/P to think that general purpose plywood could be steam treated.
(maybe some can, and some can’t. experimentation would have to be involved).
and yes, I have used 1/8” birch in model making – in the flat form. never bent. (I like it).
John
Dark_Lightning
#14 posted 07-22-2020 11:35 PM
One can also buy bending poplar plywood, which will go down to a 5” radius bend.
http://www.calpanel.com/Bending-Poplar.html
And luaun plywood, as well.
View TerriK's profile
TerriK
10 posts in 276 days
#15 posted 04-20-2021 11:34 PM
There’s always a trick!
