Has anyone ever run 240V 50hz European tools on US 220V 60hz?
I'm considering getting a tools shipped to me from Germany, but I'm concerned about the power requirements.
My thoughts….
1. It will run fine. The machines are built with +/- %10 tolerances.
2. I'll need to purchase a power converter to run the machine.,
3. I'll need to order a new power controller for the machine?
4. This is just a really, really bad idea, and I should just drop the thought from my head!
I think that it is a bad idea, and you should get the thought from your head. If I recall correctly, increasing the hz will increase the HP and motor speed beyond what it is rated for, and it will probably wear out really quickly. However, I am not an electrical engineer, so take what I just said with several grains of salt.
Isn't most stuff from Europe 3ph.
I do know that the single phase motor on my bandsaw is Italian. It's is designed to run here in the USA but the start capacitor is very unique and expensive to replace.
Something I didn't even consider when I bought it.
Good Luck
Like many things it depends on the specifics. For example, if it is a simple bandsaw with nothing more in terms of controls than a power switch, and the motor is dual rated for 240/50 and 220/60 You might be fine with doing nothing if the increased blade speed works for you application. Or you might need to change the motor pulley to result in the same blade speed.
On the other hand if the motor is not dual rated or you have other controls components to deal with like transformers, contactors, motor starters, overloads, etc. you may find yourself with a much more complex situation that would make it difficult to ensure it is electrically and mechanically safe and will function properly when run at the different line voltage/frequency.
If we know the tool, and can read the mfg data sheet; then we can help specifically.
Many newer small hand tools are multi-rated, and if they are not; higher chance that something needs changed inside (like electronic speed control, or capacitors) to make work.
Large industrial equipment designed for 50Hz can be expensive challenge to convert to 60Hz. Especially if the motors are not wound to handle differences in heat dissipation with change in frequency, and need all new motors.
The machine was a Single Phase MiniMax Elite or Hammer A3-41.
As it turns out, I'm not going to have to go that route. Until last night, that looked like the the only option for me to go. With COVID, everyone and their neighbor has 1. taken up woodworking and 2. bought up every Hammer and MiniMax J/P on the continent. With the factories shut down. Best estimates put the factories back at 100% in maybe six months.
I found a few machines in Europe, all only set up for German power.
Good news! Last night, I found one, on a shipping container, bound for the US. I've put my payment down, and will be getting a new MM Elite in a few weeks.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
