Forum topic by Noahkix | posted 07-13-2020 05:47 PM | 439 views | 0 times favorited | 7 replies | ![]() |
Topic tags/keywords: question walnut biscuit joiner joining finishing modern Hey everyone, Moving into a new apartment soon and will need a smaller dining table. I have two walnut boards that I was thinking about either making into the dining table or shelves. Dimensions and thoughts are as follows: 4 person table—-> 36”x48” I’m a little worried that the thickness will leave this small table feeling peculiarly sized. I plan on adding threaded inserts to the bottom too to prolong the life of the table / allow easier install/breakdown of the legs. I plan on joining the boards with some biscuits + glue. I imagine that once the boards are glued up, there wont be much flex, but am I wrong / should I add cleats? Alternatively, these boards would make some beautiful shelves, which I also need. Whatcha think? Any and all thoughts welcome. -- - Noah |
7 replies so far
#1 posted 07-23-2020 07:33 PM |
Noah, As I understand your description, you’re going to create a 36”x48” top and attach legs directly to the top without skirts by using threaded inserts. I don’t think that you’ll have a flex problem with the top as it’s not normally given a heavy vertical load. My concern is the leg attachment: I don’t think that simple threaded inserts would hold. Your idea of adding cleats would give a lot more depth for a hanger bolt to engage. But make sure that you allow the cleats to move as the top expands and contracts with seasonal changes in humidity. In lieu of cleats, you could use surface-mounted attachment plates. (Search Amazon for “leg attachment plates” to see what I mean.) These would give 4 screws per leg rather than a single threaded insert. And, because each plate will only constrain several inches of the top, movement won’t be a problem. But you’d be limited to short screws. You could laminate a 3”-4” square for each plate (that is, glue it on with the grain aligned with the top’s grain) and permit longer screws without risking their breaking through the upper surface. Either way, without skirts for the legs, the table will be vulnerable to catastrophic failure if you drag it across a carpeted floor—the leg will give a LOT of leverage. So lift it when you need to move it. Good luck, |
#2 posted 07-23-2020 07:58 PM |
For a leg wothout a skirt it requires a welded insert that goes in the leg and has a plate that can be grooves into the bottom of the table… |
#3 posted 07-23-2020 08:07 PM |
You could add support to the legs with pairs of wooden braces from the legs to the top with a screw holding each end. Look at some of Thomas Moser’s furniture to see the concept. If you’re not set up for steam bending, you could laminate them on a form using a rigid glue. Larry |
#4 posted 07-23-2020 08:12 PM |
The tricky thing with tables are the unexpected loads: - people pushing themselves away I’d opt for bracing of some sort -- Steve - Impatience is Expensive |
#5 posted 07-23-2020 09:01 PM |
48 inches is a very wide table. Unless you have a good bordering house reach it’s going to feel uncomfortable. Good Luck -- Aj |
#6 posted 07-26-2020 01:25 AM |
OP said it’s 36” by 48”
#7 posted 07-26-2020 01:51 AM |
These are the legs you are going to use? If you could add a foot rail from side to side across the center of the bottom rail of the legs, that would help as well. |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2811 |
Woodcarving
568 |
Scrollsawing
416 |
Joinery
1891 |
Finishing
6338 |
7903 |
32740 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1803 |
Wood & Lumber
7275 |
1631 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9654 |
