installing plywood and trim
Forum topic by mzimmers posted 07-13-2020 02:08 PM 248 views 0 times favorited 3 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
218 posts in 5161 days
07-13-2020 02:08 PM
Hi all -
I just removed a built-in refrigerator, exposing the unfinished cabinet sides. As luck would have it, the face overhangs the side by 1/4”, so I’ve ordered some 1/4” cherry plywood.
What would you recommend for adhering the plywood to the cabinet? I’m assuming some kind of nailer, but I’ve never used one. Should it be a brad nailer, or a pin nailer?
Same question applies to the top trim pieces which appear to be 3/4” solid cherry.
Thanks for any help.
-- M. Zimmers
3 replies so far
View LittleShaver's profile
LittleShaver
777 posts in 1865 days
#1 posted 07-13-2020 02:35 PM
I’d skip the nails and go with construction adhesive. These are no stress joints and you won’t have to deal with nail holes.
-- Sawdust Maker
mzimmers
#2 posted 07-13-2020 02:36 PM
for the trim, too? Just apply the adhesive and clamp it?
-- M. Zimmers
View CWWoodworking's profile
CWWoodworking
2208 posts in 1424 days
#3 posted 07-13-2020 03:07 PM
I would not use construction adhesive. Too thick and takes awhile to cure.
I would use some type of contact adhesive for plywood.
Trim can be put up with 23g pin nailer or a 18g nailer. If it’s really big or curved, 16/15g.
