Roubo style workbench overhang
Forum topic by johnthomson posted 07-12-2020 05:14 PM 299 views 0 times favorited 6 replies Add to Favorites Watch
View johnthomson's profile
johnthomson
9 posts in 310 days
07-12-2020 05:14 PM
Topic tags/keywords: roubo style bench overhang
Hello good people, I’m currently building my first proper workbench. It’s a roubo style from plans from Christopher Schwarz’ book. The bench top is cantilevered past the legs around a foot or so, it’s pretty vague. Mine will be 2 feet wide and 5’9” long. I thought I would make my leg base 4’ long, which leaves about 10 1/2” cantilevered past legs on both ends. Is this ok, or is their something I’m not considering? I will install a leg vise threaded right through the left leg, as per instruction. Hoping for advice on this. I am a novice at woodworking.
View SMP's profile
SMP
2250 posts in 711 days
#1 posted 07-12-2020 07:24 PM
Pretty much just aesthetics as long as wide enough for stability. 4’ on a 5’9” bench is plenty stable. With a leg vise no issues, only way it could really be an issue if you were making a face vise that could interfere with the planing stop or your hardware for end vise etc.
View theoldfart's profile (online now)
theoldfart
11800 posts in 3256 days
#2 posted 07-12-2020 07:57 PM
Think about any end vise that you may want to install down the road. I have a Sheldon face vise installed as an end vise.
A wagon vise is another possibility.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View CaptainKlutz's profile
CaptainKlutz
3352 posts in 2299 days
#3 posted 07-12-2020 11:26 PM
+1 leave enough room under neath the end of table to mount the end vice of your choosing.
I used a pair of antique Wilton quick release vices I restored on my bench, and they need 14” under bench for mounting.
Vise can take a lot of room under the bench.
Random pics from Woodcraft site as examples:
Good question to ask! LOL
Best Luck.
johnthomson
9 posts in 310 days
#4 posted 07-13-2020 01:29 AM
Thanks all. Good things to consider. I do have a quick release vise I’ve been considering for my end vise, only because I own it already. I’ll take a look and see what I need for clearance.
johnthomson
9 posts in 310 days
#5 posted 08-02-2020 08:16 PM
Hi, I’m building a Roubo style workbench and you all gave me good advice about cantilever of bench top past the legs. The bench is 6’ long by 23 1/4” wide. In order to accommodate my end vise, I’ll need to leave overhang 18 1/2” past the legs on end vise side. It would leave 6” overhang on opposite side. Leg assembly is 4’ long by 23 1/4” wide. Will this be a problem? Top is 4 1/4” thick, legs are 5” by 6”.
johnthomson
9 posts in 310 days
#6 posted 08-02-2020 08:25 PM
I may add a 4” end cap to bench top to get the leg assembly a little closer to centered.
