Tote and knob refinish
« back to Hand Tools forum
Forum topic by GrumpyGolfGuy posted 07-11-2020 09:22 PM 192 views 0 times favorited 3 replies Add to Favorites Watch
View GrumpyGolfGuy's profile
GrumpyGolfGuy
62 posts in 101 days
07-11-2020 09:22 PM
I’m nearing the completion of restoring a Stanley No 4½C. Looking for ways to refinish the tote and knob.
Thanks
Chris
3 replies so far
View BlasterStumps's profile
BlasterStumps
1703 posts in 1245 days
#1 posted 07-11-2020 09:52 PM
If it is Rosewood, I would not use BLO. I think it will turn quite dark. I have used Minwax Gel Stain, Brazilian Rosewood and it works okay. Then a clear satin varnish on top of that. I used a long screw thru the knob with a nut and washer on the big opening end and chucked it in my drill to spin it so i could sand it. Works fairly well.
sorry for the sideways picture
-- "...I've been through the desert on a horse with no name." So name the damned horse already!
View SMP's profile
SMP
2250 posts in 711 days
#2 posted 07-11-2020 10:07 PM
Personally i like shellac. Nice and grippy and super easy to repair.
View sansoo22's profile (online now)
sansoo22
1016 posts in 459 days
#3 posted 07-11-2020 10:42 PM
I use a tote rod with a spacer from a type 17 in the knob and then chuck it in the drill to sand it down. Totes are a bit more of a pain because they often have grain patterns going all of the place. I try my best to sand with the grain on the totes but because that isn’t always easy I take them to 400 grit using a sanding net. They are super flexible and really help take out any scratches left from sanding.
For finishes I either use gloss oil based poly or semi gloss lacquer. It just depends on the look I’m going for. Gloss poly goes on anything I had to strip and enamel or anything type 15 or later with shiny japanning. The semi gloss lacquer goes on planes I want to have a more authentic feel to.
