Another Dust Collector Question
Forum topic by Jeffnorm posted 07-05-2020 06:47 PM 274 views 0 times favorited 8 replies Add to Favorites Watch
View Jeffnorm's profile
Jeffnorm
2 posts in 41 days
07-05-2020 06:47 PM
Topic tags/keywords: dust collection filters
I have an old, old, old Jet DC 650 with an upgraded filter bag running thru a Thein separator. I have a small shop and generally only run 1 tool at once so this setup works ok. But i’m considering a further upgrade to a Wynn canister filter to replace the filter bag. My question is, should I spent the $$$ to put a filter on a dust collector that is this old, or just replace the entire unit (and get one with a cartridge already)? Do dust collectors ‘wear out’? Do impellers become less efficient over time? I’ve had no issues with my Jet but I could always use more airflow and less fine dust; it somehow seems unwise to spent quite a few dollars to upgrade an old machine and still have an old machine. I’d appreciate any thoughts.
Thanks
Jeff
8 replies so far
6310 posts in 3296 days
#1 posted 07-05-2020 08:45 PM
DCs are nothing but a motor spinning an impeller. So age doesn’t impact them as much as total usage, and in most hobbyist shops that’s not a problem. Of course, some thing deteriorate over time, like cloth bags, maybe some seals and such stuff.But you say it’s works OK and you would like to see less fine dust. Those 2 comments seem at odds to me, and at least by my standards that is a pretty inadequate DC. Even so, a canister filter may help trap a little more dust….it might even allow a (very) small increase in air flow. So if the unit is truly doing what you want, adding the filter will not hurt anything, and may help a little. Oh, impellers do not become “less effeciant” over time, but they ma get a dust buildup on the vanes that needs to be cleaned off.
View Redoak49's profile (online now)
Redoak49
4798 posts in 2791 days
#2 posted 07-05-2020 08:56 PM
You are very limited running a 1 hp Dust collector. The Thien baffle reduces the effectiveness of it. The canister filter in my opinion would help clean the air.
View CaptainKlutz's profile
CaptainKlutz
3335 posts in 2297 days
#3 posted 07-05-2020 09:07 PM
Not dust collectors do not wear out.
But
Motors do need new bearings every 10-15 years.
If start/stop the motor many times a day, the start capacitors can wear out and need replaced.
Switches also wear out after many thousand cycles.
Parts to fix any one is < $25.
Which is whole lot cheaper than a new dust collector, even if new toys make us happier? ;-)
Can also add a cartridge filter for ~$100 as DIY project too.
Click for details
YMMV
Best Luck on decision.
View ibewjon's profile
ibewjon
1754 posts in 3596 days
#4 posted 07-05-2020 09:13 PM
Only a 1 hp? I would start over with a larger machine, 2 or 3 hp. More airflow, better filtration. And an Oneida cyclone if you have the space. An upgraded DC is not a new toy, it is essential to your health.
Jeffnorm
2 posts in 41 days
#5 posted 07-06-2020 02:19 PM
Thanks, all, for the replies.
I’m both happy and sad that you’ve pushed in the direction I was already leaning. Guess I’ll start saving….
Cap’n – why did you choose a Donaldson instead of a Wynn???
ibewjon
#6 posted 07-06-2020 02:35 PM
I have the jet, which is a two micron filter, where the Wynn is a one micron. I added a wen air cleaner, and the air is very clean. I have a particulate meter hanging in the shop, and it shows very little one micron dust. No system will get it all, just going for the best I can. And there are many times to use an n95 mask, if you can find them.
CaptainKlutz
#7 posted 07-06-2020 04:11 PM
Cap n – why did you choose a Donaldson instead of a Wynn???
- Jeffnorm
1) Positive reviews and information posted in LumberJock forums on the Donaldson conversion
2) Lower cost.
Bought the Donaldson from Amazon for ~$100 with free shipping when a 3rd party supplier put it on sale. The Wynn filter was double to my door. High shipping cost of large filter was a factor in selection process too.
Cheers!
View pintodeluxe's profile
pintodeluxe
6173 posts in 3616 days
#8 posted 07-06-2020 06:16 PM
The Jet DC 650 is a dog of a tool. I like Jet tools, and have many of them. I got rid of my DC650 and never looked back. I truly believe any other DC would be better. The combination of impeller size, RPM, and overall design doesn’t give good real world performance.
I switched to a 2 hp cyclone and it is night and day better. Look for something with a larger impeller.
