Cook top
Forum topic by Ericm107 posted 07-05-2020 06:45 PM 180 views 0 times favorited 3 replies Add to Favorites Watch
View Ericm107's profile
Ericm107
1 post in 40 days
07-05-2020 06:45 PM
Hello. I have a flat cooktop stove and I want to be able to cover it when done cooking. I want to cover it with wood because of the weight and using legs so as not to be in direct contact with the hot surface. What woods would be most heat resistant and how tall would my legs have to be to prevent smoldering?
Thanks
3 replies so far
View OldBull's profile
OldBull
146 posts in 105 days
#1 posted 07-05-2020 06:56 PM
Fire Hazard
Fla state fire college #5712 engineers cert 83464.
-- My favorite square is 40 grit sandpaper
View ChefHDAN's profile
ChefHDAN
1705 posts in 3659 days
#2 posted 07-05-2020 07:15 PM
Is it an Induction top, like this one if it’s not an induction top then you should not cover it with any combustible product until it’s cooled.
If you’re thinking of a noodle board, I make them and have it printed on my invoice that the purchaser holds the sole responsibility to ensure that the range is completely cooled before placing the board on the surface. When the induction stoves first came out I would demonstrate them by cooking an item with a $100 bill between the range-top & a saute pan because they do not create any heat.
View CaptainKlutz's profile
CaptainKlutz
3377 posts in 2304 days
#3 posted 07-05-2020 08:48 PM
+1 FIRE! :)
Buy a metal one and avoid a fire department visit: https://stovetopper.com/
