Just to clarify, I intend to build a bench with 4×4s and I only have a thickness planer currently.
If the dimensional lumber is always a set thickness, if the planer rollers will press the wood down flat as it goes through, I can get two opposing sides to be flat and parallel to each other.
I can then glue those sides together with parallel clamps and run them through the planer again.
After final glue-up, my electric hand planer can take care of the rest.
No you do not need a jointer.
But
Will need to joint the boards with an alternate method to get them flat, square, and maybe parallel.
It takes straight lumber to build straight projects.
Warped, twisted, or bowed lumber can occasionally be clamped flat; but you will build in stress that eventually is released during moisture changes in wood. IME, ALWAYS need to prepare your lumber with flat edges/faces to enable a flat/straight glue up. Only way to avoid jointing lumber in shop is buying specially prepared s4s lumber from a local supplier, and ensure the lumber is stored properly to avoid movement before use.
If your 'dimensional lumber' reference above means 4×4 sticks from big box store;
they are NEVER flat, square, or parallel.
The softwood construction timbers even have rounded edges that will interfere with making a flat table top. You will find they are maximum of ~3.25" sq when you make them flat & square. Furthermore, 4×4 lumber tends to have softer center pith in it, which moves more than heartwood. It is best to avoid using pith wood in any structural elements of a project. If 4×4 has pith in it, generally better to use 2×4 or 2×6 lumber, hand selected for grain direction and no pith.
There are also many threads with folks asking 'do I need jointer', or 'how to work without a jointer' here on LumberJocks, you can search for; that will save your friends at LJ retyping all the information here again.
It's true they will be parallel BUT not always true they will be flat. Facing the firsts face on the jointer is intended to be done without forcing the board out of it's relaxed state. THEN you feeed it through the planer to make the opposite face parallel.
There are ways to accomplish this with just a planer. It just takes more time and effort
Since you are using dimensional lumber which is relatively cheap compared to hardwood lumber, what some people propose is to look through 2×10 or better yet 2×12 framing lumber for the least knotty ones you can find, cut them to rough length, pick best sections on either side of the pith and rip them apart. That'll give you the most stable wood out of the board. I believe Wood Magazine posted an article on this as well.
The rounded corners are only an aesthetic annoyance. Don't remove them before flattening the bench-top.
You don't need to get completely rid of them the first time you flatten your bench-top.
The remaining shallow grooves, if any, it will not pose any problem during workbench use.
Anyway, you might want to re-flatten/clean your bench-top after one or two years. The remaining grooves will then probably disappear completely.
You certainly don't need to suppress totally the rounded corners on the underside. This doesn't mean the underside may be left completely rough. One need to get it twist free, at least where it will sit on the undercarriage. (don't ask…)
Using warped boards is possible but,
if you don't want to loose too much material straightening them, you have to cut them in shorter length and assemble them like a kitchen counter top. What i mean: https://www.ikea.com/us/en/p/karlby-countertop-for-kitchen-island-walnut-veneer-30297641/
That is what I did because I wanted to recycle free ones which had been drying at least 20 years in an attic.
I agree with the previous comments. You don't need a jointer, but you need to joint the wood. Since you have a thickness planer, you can joint wood by using a planer sled. A planer sled is ultimately just a flat reference surface temporarily attached to the wood.
The only requirement for the sled is that it be flat WHEN YOU ATTACH THE BOARD TO IT. A simple sled can be just a melamine or particle board shelf. The sled does not need to be rigid, though some people make rigid sleds for other reasons.
You need a flat surface to work on. Your floor is NOT flat enough. Your table saw top might be flat enough. Lay the "sled" on the flat working surface, lay your wood on the sled. If you have a choice, try to put the side of the wood down that puts the gaps between the wood and sled at the edges of the board. For example, a cupped board would curve up towards the edges. This allows you to slip shims under the edges of the board to support it.
4×4 aren't really going to have cup as much as twist and bowing, but you get the idea. You want the gaps where you can get shims under them so the planer can't push the wood down.
Use as many shims as needed to keep the planer from pushing the board flat as it goes through the planer. Do not try to push the board flat. You are trying to support the board so it passes through the planer in it's relaxed state, as mentioned above.
Hot melt glue is a way to hold the shims to the sled and the board. You don't need glue between the shim and sled or board. Just beads of glue in the corners formed where the shim meets the sled and board being planed. Even masking tape can be enough to hold the shims to the sled. When going through the planer the forces are mostly pushing down on the board. Also, you want to be able to pop things loose when you're done.
You'll often see sleds with a raised edge at one end (a cleat). The idea being the board is up against the cleat to prevent the board from sliding off the sled. This is not needed as you'll see many people feed the sled in backwards when using a cleat. For the cleat to work, the cleat needs to be the first thing into the planer. The sled does not pull the wood through, it's the other way around. The wood pulls the sled through. At least for typical planners where the rollers are on top of the wood.
Also, cut your wood to rough length first. No reason to try to joint an 8 foot long board when you plan to cut it into two 4 foot lengths.
I say yes to a jointer.
The reason is sometimes woodworkers including myself get this crazy idea to buy rough lumber.
Not because it saves money or a small table looks nice made from the same tree.
For me it's how I like spending my time in my shop. Building silly fixtures and jigs isn't one of them.
Good Luck
Do you need one….....well if you want to fiddle f… around wasting time making all sorts of jigs and work arounds or hand planes then NO you don't Need a jointer.
If you want to do stock prep quickly, efficiently, accurately including the important face jointing (Some think you only need to joint the edges) then YES you need a jointer.
I don't have a jointer unless you count 2 stanley #7s and a #8. I built my current workbench out of hand selected 2×8 and 2×10 doug fir. Ripped the pith out and proceeded to hand plane the hell out of every surface. I didn't even have a planer at the time.
That being said I now have a lunchbox planer and a jointer will be my next tool purchase. I enjoy my hand tools and knowing I have the skills to use them but sometimes you just want to get milling out of the way as quick and efficiently as possible so you can get to the building phase.
You are proof that one size doesn't fit all. Of course I make jigs/buy (think Greg Jig) from time to time. But I don't have to make jigs to flatten, straighten or square up lumber.
I have been doing some reading on flattening boards the way is was done before machines. Straight edge, winding sticks, sharp planes and some know how. Even so I would probably get one side flat and then run it through the lunch box. I was able to pick up a old Craftsman 6 1/8' jointer for $150 some TLC and a fresh set of blades it would be perfect for you. Assuming you have the room for it.
I m confused guys. I own 2 jointers, and I love making jigs, fixtures and stuff to help me be able to do dead on work.
- therealSteveN
You are proof that one size doesn t fit all. Of course I make jigs/buy (think Greg Jig) from time to time. But I don t have to make jigs to flatten, straighten or square up lumber.
A planer sled and attempting to customise each little shim to give the board support under the planer roller to me sounds like a fools errand. I think I could do it faster with hand planes. I must add that I am still new to hand planes and have yet to attempt or be successful at flattening a large piece. At this point I can only say I have read the book on how and bought lots of planes, all I lack is finishing.
- therealSteveN
in my experience, planer rollers wont push cupping out of 4×4 material and so they do a pretty good job of fixing that, but they'll only address things that manifest over the length of the material within the relatively small reference area, and typically not as precisely as a jointer.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
