Not being able to remove Ridgid portable table saw blade
Forum topic by Gopa posted 07-01-2020 01:01 PM 353 views 0 times favorited 7 replies Add to Favorites Watch
View Gopa's profile
Gopa
1 post in 38 days
07-01-2020 01:01 PM
Topic tags/keywords: ridgid blade stuck
The blade is held tight to the nut. When I try to unscrew holding the arbor using the wrench, both the blade and the nut turn. Help please! Thank you!
7 replies so far
View Heyoka's profile
Heyoka
57 posts in 657 days
#1 posted 07-01-2020 01:21 PM
Use a piece of wood against the blade teeth to keep it from turning. You do know tht the nut is a left hand thread huh?
-- Heyoka
View bondogaposis's profile
bondogaposis
5803 posts in 3155 days
#2 posted 07-01-2020 01:31 PM
Push a block of scrap into the teeth of the blade then use the wrench to loosen the arbor nut.
-- Bondo Gaposis
View Robert's profile
Robert
3790 posts in 2285 days
#3 posted 07-01-2020 01:36 PM
If its a right tilt blade LOL….
MrUnix
8158 posts in 3003 days
#4 posted 07-01-2020 02:05 PM
- Heyoka
- Robert
Regardless of tilt, all you need to remember is that you put the wrench on the arbor nut and pull towards you (front) to loosen. Works the same on either left or right tilt machines.
View controlfreak's profile
controlfreak
942 posts in 405 days
#5 posted 07-01-2020 03:08 PM
I can remember going through this on an older gas grill tank. I had no idea the internal threads were reversed, man I got that sucker on tight.
View theart's profile
theart
207 posts in 1359 days
#6 posted 07-01-2020 04:46 PM
Your saw should have come with two wrenches. A box wrench for the arbor nut and an open wrench to hold the arbor itself.
- controlfreak
Every single time I need to swap pedals on a bike, I forget which one is left handed.
View jonah's profile
jonah
2123 posts in 4103 days
#7 posted 07-01-2020 07:19 PM
It’s always the other one. Then it’s the other one again when you try that one.
Then finally its the one you’re in front of, but you’ve already tightened the hell out of them.
Not unlike a USB-A plug. It’s always upside down at least twice before you get it right, despite that actually being physically impossible.
