Need A Couple Of Parts For My Craftsman Band Saw
Forum topic by mangorockfish posted 06-30-2020 01:55 AM 296 views 0 times favorited 2 replies Add to Favorites Watch
View mangorockfish's profile
mangorockfish
22 posts in 1122 days
06-30-2020 01:55 AM
Bought a Craftsman 12” band saw a few days ago and need a couple of parts for it. It’s a model 137224320. I need a table insert (2 1/2”) and the pin that goes in the edge of the table where the blade goes through. Sears Parts Direct doesn’t have them. Any help in finding these will be greatly appreciated. Thanks.
2 replies so far
MrUnix
8085 posts in 2970 days
#1 posted 06-30-2020 03:17 AM
Same size inserts as used on the 14” Delta cast iron saw and clones… I’ve always made my own inserts out of recycled milk jugs (HDPE), but you can buy them from lots of different places, even Amazon (eg: here is a 2 pack of aluminium inserts). As for the table pin, IIRC, it’s a standard taper pin that you can find at any decent hardware store… I believe it’s a #6 or #7, can’t remember which at the moment (just measure to make sure). Of course, you can find them other places for more money, like on ebay or amazon. A hex bolt can be made to work as a cheap alternative… just grind off the threads and form a taper. Chucking in a drill and using a metal file makes it pretty easy to do.
View AMZ's profile
AMZ
107 posts in 160 days
#2 posted 06-30-2020 09:42 AM
I believe the pin on the bandsaw, is threaded, with a wing nut (I believe the table is extruded aluminum). If so, any hex bolt should do, through you may need washers top and bottom.
