Rikon Bandsaw
Forum topic by murphy5900 posted 06-29-2020 11:38 PM 183 views 0 times favorited 1 reply Add to Favorites Watch
View murphy5900's profile
murphy5900
1 post in 8 days
06-29-2020 11:38 PM
Folks:
I have an older (2003) and early Rikon RK14CS bandsaw. I cannot remove the bottom wheel no matter what I do. I removed the C clip after calling Rikon, but no luck. Any ideas?
1 reply so far
View CaptainKlutz's profile
CaptainKlutz
3167 posts in 2265 days
#1 posted 06-30-2020 05:26 AM
Several possibilities:
1) Use a 2 or 3 jaw puller:
The jaws rotate for inside or outside pull.
https://www.harborfreight.com/three-jaw-puller-set-3-pc-63953.html
Prefer the 3 jaw if there is room between the spokes of the wheel?
Autozone loaner program will rent pullers for free.
2) Use a bearing separator:
https://www.harborfreight.com/bearing-separator-and-puller-set-62593.html
These support the back side of hub/pulley better, providing there is space for the 2 opposite screws to attach to back plate. The back plate taper gets into a small space, and forces the bearing forward.
Autozone rents these for free too.
3) Use extreme brute force with a slide hammer:
https://www.harborfreight.com/9-way-5-lb-slide-hammer-and-puller-set-56505.html
If you get slide hammer set with 3-4 long ‘fingers’ for pulling bearings, can grab back of wheel hub and knock it loose.
Autozone rents slide hammer for free, but it is not a complete set. Some locations rent a large 3 jaw puller that has same threads as slide hammer. Rent both, replace the center screw with slide hammer threads.
I use ALL of these tools in this progressive order to remove stubborn bearings when I refurbish rusty old tools.
Hope this helps.
Best Luck.
