Q. on Spraying Lacquer
Forum topic by unclearthur posted 06-28-2020 06:57 PM 448 views 0 times favorited 9 replies Add to Favorites Watch
View unclearthur's profile
unclearthur
386 posts in 2913 days
06-28-2020 06:57 PM
Just a quick question: I’m spraying clear nitrocellulose lacquer through an HVLP.
When I open the gallon can of lacquer, there’s quite a thick white film at the bottom. I tried stirring it in, but it doesn’t seem to dissolve very easily. I wonder if I am better off just leaving it alone and just stirring the liquid.
(I do filter the laqcuer before I pour it into the sprayer).
Does anyone know what the white stuff is? Mix it or leave it alone?
Thanks for all replies.
9 replies so far
View LeeRoyMan's profile
LeeRoyMan
1876 posts in 852 days
#1 posted 06-28-2020 07:09 PM
That’s the flattening agent. Depending on the sheen your using.
Yes, keep it stirred up good, or you will get different sheens as you spray and it settles.
View John Smith's profile (online now)
John Smith
2954 posts in 1288 days
#2 posted 06-28-2020 08:25 PM
what does the “sheen” on the can say ?
gloss, semi-gloss, satin, matte, etc.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View farmfromkansas's profile
farmfromkansas
220 posts in 739 days
#3 posted 06-28-2020 10:04 PM
If you don’t stir it up, it will be gloss. Flattening agents are additives.
unclearthur
#4 posted 06-28-2020 10:43 PM
- John Smith
Satin.
Thanks for the answers, I’ll stir it.
View CWWoodworking's profile
CWWoodworking
1920 posts in 1304 days
#5 posted 06-28-2020 10:47 PM
Stirred. Not shaken. Wait, maybe it’s the other way around…
View hkmiller's profile
hkmiller
247 posts in 1206 days
#6 posted 06-29-2020 11:55 AM
Keep stirring. It will dissolve.
-- always something
John Smith
#7 posted 06-29-2020 12:38 PM
all the above information is good.
the sediment in the bottom of the can is the correct amount of an added
solid material that gives the finish that is listed on the can. (satin, in this case).
ALL of the sediment must be fully stirred until all of the sediment is brought up
evenly into solution – and stirred frequently during the application process.
(it says so right in the instructions on the can).
if you don’t do it, you may experience “less than” satisfactory results in your finish.
let us know how it turns out for you.
Edit: you have a couple dozen very nice projects posted. what have you used for
finishing before this particular “sediment” issue ??
unclearthur
#8 posted 07-01-2020 07:02 AM
- John Smith
Thanks, almost always brushed poly in the past, or just used Danish oil. Just starting out spraying. Results have been mixed but it sure is a lot faster.
And you guys were right, it all dissolved with stirring. I was just being impatient.
Thanks all
John Smith
#9 posted 07-01-2020 11:09 AM
I have had paint and finishes that have sat for so long that there was a half inch
or more of the “sediment” in the bottom of the can that had to be broken up with
screwdrivers and other heavy duty tools before I could even start to use a mechanical
mixer in a drill motor.
“Back in the Day” when we used lead based paints, stirring the bottom of the can
was “required” before doing anything. (lead is heavy and sinks fast).
but the regiment is still the same today – no matter what finish you use.
stir stir stir then filter then use.
looking forward to seeing your completed projects.
