How would you cut the notches on these legs?
Forum topic by ravensrock posted 06-27-2020 02:20 AM 768 views 0 times favorited 12 replies Add to Favorites Watch
View ravensrock's profile
ravensrock
513 posts in 2758 days
06-27-2020 02:20 AM
I’m getting ready to make an outdoor table for my daughter out of cedar. I want to do something like in these pictures with a notch on the inside top of each leg to accept the aprons. How would you cut these? Use a router to hog out most of it and finish with a chisel? All hand tools using saw and chisels? Thanks in advance!
-- Dave, York, PA, Wildside Woodworking
12 replies so far
View marc_rosen's profile
marc_rosen
180 posts in 4296 days
#1 posted 06-27-2020 03:06 AM
Hi Dave,
You’re just a few miles (30 maybe?) up the road from me. I was planning to bike up to York tomorrow on the Rail Trail. By the way, nice work on those projects.
Your suggestion to rout and square it with a chisel sounds acceptable. You can also use the table saw with a stop cut to define your edges before routing and maybe score a few lines to make that routing easier. I’m guessing you don’t have a hollow chisel mortiser, but that would also be helpful to get the square in the corner.
Hope you have an easy time making this, Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
View SMP's profile
SMP
4141 posts in 1021 days
#2 posted 06-27-2020 03:22 AM
I have a wheel marking gauge I would use to score all the like lines out all at once, then switch to mark the others. For just 4 legs I would probably just use my tenon saw to angle cut to the lines as best I could then chop with a wide chisel and clean up with the chisel. If I was just in a hurry to “get it done”, I would probably use my table saw for most of it, or if I had to make a bunch of the same legs.
ravensrock
#3 posted 06-27-2020 03:24 AM
Thanks for the input Marc. I guess we’re practically neighbors! Good idea about the table saw. That would give me nice clean edges at least part of the way. I don’t have a hollow chisel mortiser.
View LeeRoyMan's profile
LeeRoyMan
1833 posts in 842 days
#4 posted 06-27-2020 01:44 PM
If you aren’t very good at chiseling and you didn’t mind glue lines.
View TheWop's profile
TheWop
5 posts in 372 days
#5 posted 06-27-2020 07:59 PM
How about using a multi-tool type saw?
ravensrock
#6 posted 06-28-2020 03:53 AM
Clever idea but not sure I want glue lines. TheWop- I thought about that option. Have a Bosch one that I rarely use. I think I’ll see how a handsaw and chisel work and pull out the multi-tool if need be.
If you aren t very good at chiseling and you didn t mind glue lines.
- LeeRoyMan
- TheWop
LeeRoyMan
#7 posted 06-28-2020 04:00 AM
I think the Multi-tool is a good idea. Get rid of most of the material then clean up with a chisel.
View JIMMIEM's profile
JIMMIEM
212 posts in 1957 days
#8 posted 06-28-2020 02:01 PM
Plunge router with guide bushing. Use a right angle ‘jig’. Clean up the rounded inside corners with chisel or multitool.
View AESamuel's profile
AESamuel
111 posts in 2338 days
#9 posted 06-28-2020 03:28 PM
I’d use a router or a forstner bit in a drill press to hog out most of it, then finish up with a nice sharp chisel.
ravensrock
#10 posted 06-29-2020 01:25 AM
I think I’m going to use a plunge router and chisel. Thanks for the advice!
I d use a router or a forstner bit in a drill press to hog out most of it, then finish up with a nice sharp chisel.
- AESamuel
View Jimothy's profile
Jimothy
68 posts in 2055 days
#11 posted 07-10-2020 03:31 AM
An angle jig and a dado stack
Smitty_Cabinetshop
17360 posts in 3734 days
#12 posted 07-10-2020 03:37 AM
Fine-ish tenon saw and a chisel will do that work.
-- Don't anthropomorphize your handplanes. They hate it when you do that. - OldTools Archive -
