What would be a good tool for sanding a deck after I pressure washed it?
Forum topic by MiniMe posted 06-22-2020 06:01 PM 449 views 0 times favorited 17 replies Add to Favorites Watch
View MiniMe's profile
MiniMe
406 posts in 858 days
06-22-2020 06:01 PM
Hi guys
What would you use (if you would do that) to sand a deck after you pressure washed the deck?
The wood is cedar
thanks
MM
17 replies so far
View Splinterlicker's profile
Splinterlicker
14 posts in 52 days
#1 posted 06-22-2020 07:30 PM
What kind of square footage are we talking?
If it’s something like a 10×20 deck grab yourself a 4”x24” sander and some kneepads. The sander will come in handy later for stuff like tabletops and benches.
Makita and Triton both make good models.
If your deck is half the square footage of your house, as seems to be the trend anymore, you might want to rent something like this
If you use the belt sander have a dust collector hooked to it and wet the areas you’re sanding with a spray bottle as you go, just enough to keep the dust damp. Sparks from sanding the screw heads can light the dust on fire pretty easily.
I’ve had to figure out how to extinguish a fire in my Makita in a hurry… More than once…
MiniMe
#2 posted 06-22-2020 07:58 PM
The size is 10×10
Renting a floor sander is out of question as I have to sand some rails and boards that top the fence at chest level
no nails, I used a homedepot sold under deck rail that you use to attach the floor
https://www.homedepot.ca/product/peak-products-hidden-deck-fastener/1000660410
I a afraid to use the band sanders as I can’t control the depth and it might make small gaps in the wood
I also have a sheet sander but that is small…
I am thinking about a circular (or orbital?) sander
View tvrgeek's profile
tvrgeek
1008 posts in 2456 days
#3 posted 06-22-2020 08:28 PM
A length of 2×4 with 60 grit automotive self-stick strips. Will knock down the high spots pretty quick and you can then stain it.
With all our power tools, we forget how easy it is to do some things by hand.
MiniMe
#4 posted 06-22-2020 08:42 PM
in some spots I was pretty rough with the power washing and I need to make that look better…in some other areas the wood lost the brown stuff between the white lines in the picture, so I want to level those
MiniMe
#5 posted 06-23-2020 01:08 AM
80 grit and one of these
seems to be working, better and less destructive than the pressure washer
View BurlyBob's profile
BurlyBob
7708 posts in 3072 days
#6 posted 06-23-2020 04:51 AM
I honestly think all you want to do is scuff the area. Like many things in life less is more. My advice is get a drywall sander thingy much like a floor mopper. Than give it a good overall even sanding nothing to excessive your just trying to get the wood to absorbed the deck finish. Just make sure your deck finish has a really good UV protection rating.
You’ll do just fine.
View nickbatz's profile
nickbatz
532 posts in 887 days
#7 posted 06-23-2020 05:09 AM
I personally would just use a random orbit sander.
MiniMe
#8 posted 06-23-2020 09:44 AM
I already had one but it did not work
You need to be able to apply some pressure on it and the mop like thing is not working
You ll do just fine.
- BurlyBob
MiniMe
#9 posted 06-23-2020 09:46 AM
I tried to use a sheet sander as well but it did not work well
The above is the best as it allows you long strokes along the fiber
- nickbatz
MiniMe
#10 posted 06-23-2020 10:08 AM
It is going to rain and I am not done with the sanding
Will it hurt if the deck gets when where I sanded it already ?
Should I drop a tarp on it or let it soak a little?
I want to know if the now sanded areas-sanded after pressure washing) will lose some or all the capacity to absorb the stain
View JackDuren's profile
JackDuren
1258 posts in 1766 days
#11 posted 06-23-2020 02:10 PM
It’s fine…. I belt sand the joints on my deck as my one year old grand daughter got splinters crawling on it. Belt sanded and smoothed out the edges. Not a problem anymore. The screws were countersunk…
Pressure wash every year without a problem…
MiniMe
#12 posted 06-23-2020 02:17 PM
It s fine…. I belt sand the joints on my deck as my one year old grand daughter got splinters crawling on it. Belt sanded and smoothed out the edges. Not a problem anymore. The screws were countersunk…
- JackDuren
The belt sander is too heavy and I can’t control it properly and do the areas that I want
JackDuren
#13 posted 06-23-2020 02:35 PM
- JackDuren
The belt sander is too heavy and I can t control it properly and do the areas that I want
- MiniMe
You can use a ROS. If the screws are locking the deck boards down, after you sand you should have no problems after that..
View bmerrill's profile
bmerrill
106 posts in 880 days
#14 posted 06-23-2020 02:43 PM
Wouldn’t sand.
-- You are not told the truth, you have to learn the truth.
View GR8HUNTER's profile
GR8HUNTER
7668 posts in 1519 days
#15 posted 06-23-2020 02:58 PM
a little late to this party BUT that is why they make different spray ends for the pressure washer :<)))
