How to glue in magnets
Forum topic by Lt_scout posted 06-21-2020 12:59 AM 843 views 1 time favorited 18 replies Add to Favorites Watch
View Lt_scout's profile
Lt_scout
49 posts in 1791 days
06-21-2020 12:59 AM
Hi Guys,
Any thoughts on gluing 1/4” neodymium magnets into plywood. I have tried epoxy, silicone, gorilla glue and I’ve come full circle to yellow wood glue.
I make and sell these specialty artist easels and so far so good but today a customer had a magnet come out.
I’m reading that it’s a good idea to scratch up the glue side and use isopropyl alcohol to clean it, then epoxy.
Anyone got this magnet gluing figured out?
-- When you know you can do more with less, you will require less to do more.
18 replies so far
View CWWoodworking's profile (online now)
CWWoodworking
2129 posts in 1399 days
#1 posted 06-21-2020 01:08 AM
Try a caulk, geocel for rv’s.
The stickiest caulk I ever used.
View Redoak49's profile
Redoak49
5369 posts in 3209 days
#2 posted 06-21-2020 01:28 AM
I drill the holes slightly undersized and press fit with yellow glue. Slight abrasion of the magnet glue surface is good.
You can take a 1/4” drill bit and reduce the diameter slightly with emery paper or use a 6 mm drill bit.
View MrWolfe's profile
MrWolfe
1668 posts in 1344 days
#3 posted 06-21-2020 01:34 AM
I sometimes drill it a little deeper (a millimeter or so) and then glue a wooden dowel into the hole over the magnet and cut it flush with the surface. It hasn’t failed yet but the wooden dowel plug has to be pretty thin.
Jon
View jonah's profile
jonah
2168 posts in 4519 days
#4 posted 06-21-2020 01:57 AM
Epoxy has always worked for me, and I’ve done it at least twenty times.
I do rough up the bottom side of the magnet with coarse sandpaper.
View MrUnix's profile
MrUnix
8756 posts in 3419 days
#5 posted 06-21-2020 03:27 AM
For the speed rotors I made for my scroll saw (20 magnets around the edge of a 2” wooden disc), a 1/4” forstner bit made the hole for them to sit in, and then they got glued in with regular titebond wood glue. The rotors spin pretty fast, but I haven’t lost a magnet yet. I imagine that epoxy would be even better.
View CaptainKlutz's profile
CaptainKlutz
4870 posts in 2715 days
#6 posted 06-21-2020 03:59 AM
- jonah
+1 Have had zero magnet failures with both epoxy or thick CA glue; providing you sand the surface with 60-80 grit and clean all skin oils off with acetone or lacquer thinner first.
YMMV
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
Lt_scout
#7 posted 06-21-2020 04:25 AM
OK… excellent, this helps me a lot. good dope guys, thanks. I think the yellow glue is plenty sufficiant to hold providing the magnet is rough and clean, is what I’m deducing from you all and my own experience. But the epoxy seems like the ultimate method.
...But I have had magnets come out even after epoxying them in, but I didnt clean with spirits first.
rather not work with epoxy for production work, might gamble with the yellow glue.
Thanks again fellas
View Walker's profile
Walker
465 posts in 1693 days
#8 posted 06-21-2020 04:45 AM
I’ve glued many Neo Magnets like that into wood with common super glue. Home Depot HDX brand is cheap and works great. You can also buy ring magnets that accept a screw.
https://www.kjmagnetics.com/products.asp?cat=16&gclid=EAIaIQobChMIsv6amYyS6gIV0cDACh2hvwDKEAAYASADEgJ_G_D_BwE
-- ~Walker
View therealSteveN's profile
therealSteveN
8683 posts in 1795 days
#9 posted 06-21-2020 05:30 AM
I sometimes drill it a little deeper (a millimeter or so) and then glue a wooden dowel into the hole over the magnet and cut it flush with the surface. It hasn t failed yet but the wooden dowel plug has to be pretty thin.
Jon
- MrWolfe
I’ve only used them on knife blocks, and I use face grain plugs, usually a contrasting wood to cover the magnet. You are correct, a thin slice or you start blocking the magnet.
-- Think safe, be safe
View wildwoodbybrianjohns's profile
2836 posts in 768 days
#10 posted 06-21-2020 06:19 AM
I use CA glue, clean first with acetone. No failures to date.
-- WWBBJ: It is better to be interesting and wrong, than boring and right.
View robscastle's profile
robscastle
8236 posts in 3425 days
#11 posted 06-21-2020 07:04 AM
-- Regards Rob
View tvrgeek's profile
tvrgeek
2272 posts in 2870 days
#12 posted 06-21-2020 07:11 AM
JB Weld. I clean with alcohol first.
View Woodbum's profile
Woodbum
957 posts in 4286 days
#13 posted 06-21-2020 01:59 PM
Medium or thick CA glue works great.
-- "Now I'm just another old guy wearing funny clothes"
View Gene Howe's profile
Gene Howe
12390 posts in 4649 days
#14 posted 06-21-2020 03:19 PM
Like everyone has suggested, an alcohol massage does the trick. They love a good rubdown.
I use vinyl or rubber gloves when using CA. They also prevent transfer of skin oils.
View splintergroup's profile
splintergroup
5763 posts in 2443 days
#15 posted 06-21-2020 03:21 PM
You need some “tooth” for the adhesive. I’d recommend epoxy or something “sticky”, PVA glue and metal just isn’t very strong.
The ultimate is countersink style (which can be pricy)
or magnets with a step to trap the glue
