Threeway miter joint
Forum topic by pontic posted 06-17-2020 09:50 AM 664 views 0 times favorited 19 replies Add to Favorites Watch
View pontic's profile
pontic
797 posts in 1411 days
06-17-2020 09:50 AM
Does Anyone do these on a regular basis? Do you use a hollow chisal mortiser or just all hand tools.
-- Illigitimii non carburundum sum
19 replies so far
View HokieKen's profile
HokieKen
14499 posts in 1941 days
#1 posted 06-17-2020 12:48 PM
Wow. I have never (and likely will never ;-p) made anything remotely like that. I’m not even sure I could get it put together let alone cut. I’ll be following to see what others have to say because I’m very curious!
-- Kenny, SW VA, Go Hokies!!!
View GR8HUNTER's profile
GR8HUNTER
7648 posts in 1515 days
#2 posted 06-17-2020 02:57 PM
Wow. I have never (and likely will never ;-p) made anything remotely like that. I m not even sure I could get it put together let alone cut. I ll be following to see what others have to say because I m very curious!
- HokieKen
just a bit harder then the sliding dumba$$ joint Kenny :<))
View therealSteveN's profile
therealSteveN
5922 posts in 1376 days
#3 posted 06-17-2020 03:56 PM
Get started with Japanese joinery….. Appears they show the same exact joint.
Rat cheer.
https://www.finewoodworking.com/2015/10/06/learn-about-japanese-joinery
Hint: A lot more thinking, than sawing.
-- Think safe, be safe
View AlaskaGuy's profile
AlaskaGuy
5860 posts in 3111 days
#4 posted 06-17-2020 04:39 PM
Life it too short too spend it on a joint I’ll never use.
If I really wanted to make similar (meaning 3 way 45 the would be strong enough) I’d cut the 45’s and use the Festool domino.
https://www.google.com/search?source=univ&tbm=isch&q=3+way+miter+joint+with+festool+domino&client=firefox-b-1-d&sa=X&ved=2ahUKEwiw5_y1pInqAhUrHzQIHTmZD_kQsAR6BAgIEAE&biw=1600&bih=758
Yeah, I suppose I’m getting lazy in my old age.
View waho6o9's profile
waho6o9
8917 posts in 3379 days
#5 posted 06-17-2020 04:47 PM
https://www.youtube.com/watch?v=rRZBUbMjxWY
Looks like Johnathan Katz-Moses ^ is making the Kane Tsugi joint.
View Aj2's profile
Aj2
3174 posts in 2600 days
#6 posted 06-17-2020 06:46 PM
That’s the kind of joint that causes the F word to fly out of my mouth just before I throw it into the pile of doomed projects.
Good grief what a over complicated mess.
Good Luck
-- Aj
View wildwoodbybrianjohns's profile
1815 posts in 349 days
#7 posted 06-17-2020 07:22 PM
I bet it sure is pleasing if and when that joint comes together perfectly. Like nearly a godly moment.
I agree with AlskaGuy. Time is short. I could make three boxes in the time it would take me to screw this thing up.
-- Wildwood by Brian Johns: The Big Bang: Nothing - exploded into Everything. Thanks to Nothing.
View sras's profile
sras
5534 posts in 3931 days
#8 posted 06-17-2020 08:52 PM
I’d do a youtube search
Here is one I found
Update: Somehow I missed that waho6o9 had already suggested this. Oh well…
pontic
#9 posted 06-17-2020 11:48 PM
Lesser Godly moment because I chose air dries Box Elder
View sras's profile
sras
#10 posted 06-18-2020 12:19 AM
Nice job! That didn’t take you long!
HokieKen
#11 posted 06-18-2020 12:22 PM
Well done Pontic! How did you go about it? Hand or power tools?
pontic
#12 posted 06-18-2020 02:58 PM
This was the 12th attempt. Used combination of power and hand tools.
View Redoak49's profile
Redoak49
4798 posts in 2791 days
#13 posted 06-18-2020 03:40 PM
Pontic…Excellent!!
pontic
#14 posted 06-19-2020 12:27 AM
Definitely need a double track marking gage. I use a veritas wheel cutter type. Mortice machine helps to for the cheek cuts. A very very sharp 1/4 and 1/8 chisel se. I use Japanese hand saws and a chop saw. The pieces must be exactly square and equal. Not easy at all.
Never make one unless I’m paid a lot for it.
View robscastle's profile
robscastle
7237 posts in 3006 days
#15 posted 06-19-2020 11:41 AM
I made a small seat table using something similar but not quite as complex.
might be worth a check out. was a right pain to make!
https://www.lumberjocks.com/robscastle/blog/95778
-- Regards Rob
