Resawing help
Forum topic by groland posted 06-15-2020 07:39 PM 418 views 0 times favorited 5 replies Add to Favorites Watch
View groland's profile
groland
230 posts in 4296 days
06-15-2020 07:39 PM
Topic tags/keywords: resawing help
I have an old Delta bandsaw ca. 93.5” blade with a resaw capacity of ca. 7”.
I am using a Kreg fence to which I added a 6” extension made of 3/4” MDF. The table, fence and blade are square to each other. I am using a 1/2” 3 tpi skip tooth blade.
When I tried resawing a piece of poplar to two slices ca. 5/8” each, the saw would not stay on the line but veered off to the outside of the fence.
Also the cut end of the board closed up so tightly I had to jam. Screwdriver into the cut to back it out of the saw.
What should I do?
5 replies so far
View Jim Finn's profile
Jim Finn
2849 posts in 3806 days
#1 posted 06-15-2020 07:47 PM
The blade seems to be dull. Screwdriver inserted between the pieces works well if you get it in place as soon as you can. Every time my re-saw efforts veer to one side or the other I put in a new blade. Works like a charm.
-- No PHD just a DD214 Lubbock Texas
View HokieKen's profile
HokieKen
15158 posts in 2023 days
#2 posted 06-15-2020 07:50 PM
Do you have drift when you flat saw a board with the same setup? Sounds to me like maybe the fence just needs to be adjusted to compensate for drift.
-- Kenny, SW VA, Go Hokies!!!
View tvrgeek's profile
tvrgeek
1054 posts in 2533 days
#3 posted 06-15-2020 08:05 PM
Drift is caused by #1 blade, #2 setup. I never got anywhere until I followed the Snodgrass setup procedure.
I keep several wood shims handy for wood with stress in it.
View Madmark2's profile
Madmark2
1719 posts in 1472 days
#4 posted 06-15-2020 08:09 PM
Cut from the other end of the board.
-- The hump with the stump and the pump!
View AlanWS's profile (online now)
AlanWS
88 posts in 4442 days
#5 posted 06-24-2020 07:31 PM
The blade can be too dull for resawing, but plenty sharp for cutting thinner stock. Matthias Wandel explains it here: https://woodgears.ca/bandsaw/resaw.html
-- Alan in Wisconsin
