Forum topic by motion | posted 06-12-2020 03:17 PM | 286 views | 0 times favorited | 4 replies | ![]() |
I’m finally getting ready to put the planer back together. The question I have is both the in and out feed rollers use oil fed bronze bushings inside cast iron blocks, oil is fed through the tension adjustment screws down pass the spring and into the bushing/shaft. When putting this back together should I consider putting sawdust or foam of some type, in the core of the spring to act as a sponge to retain the oil and dispense it more slowly? there was some grease and sawdust in there when I cleaned everything up and I thought it was build up from years of use. I didn’t know they needed to be oiled, I thought they had bearings. Thanks in advance |
