project help
Forum topic by woodpena posted 06-08-2020 03:40 PM 556 views 0 times favorited 6 replies Add to Favorites Watch
View woodpena's profile
woodpena
2 posts in 540 days
06-08-2020 03:40 PM
Topic tags/keywords: box upholster project help velvet
i am making a wooden bow tie box holder and it has 40 cubbies. I was planning to line the cubbies with velet and do not the best way to go about lining each cubby. Does anyone have any suggestions? Please help!
View GrantA's profile
GrantA
3164 posts in 2691 days
#1 posted 06-08-2020 03:44 PM
Research flocking, that’s what you’ll want to do here
woodpena
2 posts in 540 days
#2 posted 06-08-2020 03:50 PM
Thank you. Would that work on already stained wood? If a visual helps: Image a tic tac toe board and I have to line each individual cubby.
View LesB's profile
LesB
3138 posts in 4727 days
#3 posted 06-08-2020 05:50 PM
I have used adhesive backed felt and there is adhesive Velvet available (Rockler and others have it). Cut to size, remove the backing and install.
You just have to be careful putting it in because the adhesive is quite tacky. One way is to peal back one edge and put in place them carefully pull the rest of the backing as you press it into place.
-- Les B, Oregon
View Rich's profile
Rich
7561 posts in 1873 days
#4 posted 06-08-2020 05:57 PM
+1 for flocking. The advantage of it over felt is that it’ll fully and evenly cover the inside of the cubbies. Anything that you cut and stick will have seams in the corners. The kits are inexpensive. Grab some glue and flocking material in the color you want and do a practice run on a small mock up of your piece.
There have been some good tips posted on LJ that might help if you can find them. One was to do the flocking inside a box or something else to catch the excess so you can put it back in the bag.
View HokieKen's profile
HokieKen
19846 posts in 2422 days
#5 posted 06-08-2020 05:58 PM
Make that +2 for flocking.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View Foghorn's profile
Foghorn
1344 posts in 670 days
#6 posted 06-08-2020 10:31 PM
- HokieKen
I’m wavering on flagging this flocking post. :)
-- Darrel
