Forum topic by pomfritz | posted 06-07-2020 09:59 PM | 921 views | 0 times favorited | 24 replies | ![]() |
My wife took up Kung fu a few years back and she is doing it pretty intensively now. Recently she asked about using the garage as a work out area. Hmmm. This was always my domain with my woodworking area and also a space I used to restore an 83 Vanagon Westfalia camper. Anyways I ageed to look into what we could do. I found what I hope is a suitable floor for all these activities. We laid it a few weeks back and it looks tough enough while being less hard than concrete. I had my eyes on epoxy but that was not going to work We found some PVC interlocking tiles from Perfection Floor tile. They had some close outs on black and grey in limited quantities. Used an online designer to make a pattern that we liked. Turned out pretty nice. Added a 4×6 mirror. Paint and it’s starting to look pretty nice. She actually told me that she would like her Taisifu (really remarkable person) to bless the space. So I need to turn this into something blessable. It’s certainly has gotten the creativity juices flowing and I’m digging it. So I’ve really enjoyed following others projects and renos so here’s mine. Also some of this stuff will be brand new to me and probably would like to get some ideas. |
24 replies so far
#1 posted 06-07-2020 10:18 PM |
You let her take over your space I guess her Kung fu is better then yours. :) -- Aj |
#2 posted 06-07-2020 11:31 PM |
She’s an awesome woman who has given me time to heal and so the things I needed back earlier and now it’s her time. She’s making the most of it and I want to support her as much as I can. |
#3 posted 06-07-2020 11:40 PM |
So got a good deal on the tiles in part because the dark grey can change between lots. I had no idea how many shades it could be. It was really hard to tell differences until you joined them together. The seam would either be almost invisible or really not. Tried to place them in such a way to minimize the differences and so there was a lot of trial and error. In the end I’m happy with the results and most differences are hidden towards the sides. The cart was something I made awhile ago and it served its purpose of allowing me to stack stuff on top of other stuff really well. This has now gone to my daughter whom has gotten the bug of making stuff. Love it! |
#4 posted 06-07-2020 11:43 PM |
I also added an outlet per the wife’s request. An electrician told me I could tap it off the doorbell transformer! Woohoo. Really didn’t want to cut into the wall after the work fixing and painting it. So I painted the conduit white. More electrical to follow as I formulate what and where. |
#5 posted 06-07-2020 11:50 PM |
So the first storage upgrade was finished recently. The Yakima rack was on the wall in a different location and the opening was facing the wall. Had an idea to turn it around and cram as much camping gear into it as I could. Got some love edge redwood boards really cheap locally and epoxied it. Used a French clear to hang the on the wall and used hooks on the redwood to hang on the rack. I really like the simplicity and strength of the cleats and want to use them where I can. Question what is the weight capacity of a cleat? First cabinet will probably be 24×48 made of 3/4 ply. Filled with paint cans and such. I was thinking of adding a secondary cleat but not with a 45 deg cut. Just let it rest on a 90. Sorry about the sideways pics. Don’t know why it does that or how to fix. |
#6 posted 06-07-2020 11:53 PM |
Here’s a nice pic of the floor. As I finally got things put away, I now had the floor open like this for the first time and sealed it up. |
#7 posted 06-08-2020 12:00 AM |
Next up will be a cabinet with sliding doors near the left side of the garage opening. An idea on the doors to have a shoji look is percolating. Either using some laminated shoji paper with a 1/8” backing or maybe an opaque acrylic plastic. In any case it should hold up to some use. But I like the look and it would fit nicely with the theme and my heritage. This will set the design for the rest of the cabinets. |
#8 posted 06-08-2020 12:19 AM |
Here’s Stefi. The main occupant of the garage. Most of the work was done in the garage. The floor really took a beating. Now that the heavy lifting is done I should be able to maintain her without messing up the floor.
#9 posted 06-08-2020 02:20 AM |
As soon as I saw the big cardboard box on the floor I said to myself “this person works on an old car in there”. Nice work on the garage and the van. I’ve seen plenty of Ford Transit vans setup that way but this is the first VW I’ve seen as an expedition rig. |
#10 posted 03-06-2021 09:07 PM |
Thought I’d post an update of the progress so far. Had a water leak so that delayed some things for a while and am back in project mode. This was a test build of some cabinets I want in there. I plan on making some sliding doors in a shoji style. Found some tough shoji paper that should hold up well. I wanted a router table with height adjustment built into the top. The Triton router has this feature built in so you don’t have to purchase a separate lifting mechanism. The table I copied from a German woodworker, Andreas Kalt. It needs to be reworked as its sagging. The wood on the side is just not enough to weight. I like the concept though and will probably keep it like this. I’ll build a box for the saw and store the table in it while not is use. I found that my little Skil drill press was. It up for much strenuous drilling without locking up. I like older tools so I picked up an old Delta press from the 40’s and restored it. Sorry for no complete pic but this is what I’ve got so far. It turned out great and is such a beast. Picked up a few missing bolts on eBay and the motor needed some work which I had a local shop do. Love using it. I love French cleats! Gong this route opened up so many possibilities and overcame my analysis paralysis of where to put things. So simple to reconfigure.
#11 posted 03-08-2021 04:39 AM |
Nice garage makeover! You might want to post your projects on your member page. |
#12 posted 03-08-2021 08:15 AM |
The finished project. Had some left over live edge redwood. Coated in resin to harden the wood and finished in Spar Urethane. The moon is for her middle name. Found it on Etsy. Thanks for the suggestion. Still learning this site. |
#13 posted 03-08-2021 09:00 AM |
Nice job |
#14 posted 03-08-2021 02:16 PM |
Very cool upgrades, great ideas. -- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain |
#15 posted 03-08-2021 04:07 PM |
Made some carts to get stuff off the ground and for the wife’s equipment. What I love about making these is the ability to fit it to the space. There was a little room between two poles so I took advantage of it for her cart. I’ll probably do a nicer display for her weapons later as I see what she accumulates. But these were good projects for me to build boxes and see all the little ways I could screw them up. Usually some small misalignment after thinking it was good |
Forum | Topics |
Woodworking Skill Share
13250 |
Woodturning
2831 |
Woodcarving
580 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6408 |
7948 |
32964 |
CNC Woodworking
335 |
Hand Tools
6491 |
Jigs & Fixtures
1826 |
Wood & Lumber
7313 |
1647 |
Focus on the Workspace
2645 |
1273 |
Woodworking Trade & Swap
5439 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9686 |
