Applied grid onto glass
Forum topic by 1thumb posted 06-04-2020 03:10 AM 313 views 0 times favorited 14 replies Add to Favorites Watch
View 1thumb's profile
1thumb
183 posts in 2933 days
06-04-2020 03:10 AM
Seven windows apprx 60”x20”, non operational, glass rectangles w/stop. She wants wood, no plastic. 9 lites. I’m going to get the smallest mull I can find, cut to fit. How adhere to glass? Need to do both sides so you can’t see back of mull and adhesive from outside?
14 replies so far
View Lazyman's profile
Lazyman
5444 posts in 2164 days
#1 posted 06-04-2020 03:56 AM
I am not clear what you are asking. Are you trying to turn a window into a divided light window?
View Chenier's profile
Chenier
14 posts in 483 days
#2 posted 06-04-2020 11:12 AM
In all of the faux divided light windows I’ve seen, the muntins are built as a frameless grid that attaches at its ends to the window rails and sashes. Typically held in place with a clip having a little tounge that slides between the glass and the rail or sash holding the glass in place.
The faux muntins are not glued to the glass anywhere. The idea is to make them removable for cleaning and/or replacing the glass.
1thumb
#3 posted 06-04-2020 12:48 PM
- Lazyman
Yes.
1thumb
#4 posted 06-04-2020 12:50 PM
In all of the faux divided light windows I ve seen, the muntins are built as a frameless grid that attaches at its ends to the window rails and sashes. Typically held in place with a clip having a little tounge that slides between the glass and the rail or sash holding the glass in place.
- Chenier
Yes. But I want to cut, attach wood to glass. Caulk, paint, get check
View LittleShaver's profile
LittleShaver
676 posts in 1396 days
#5 posted 06-04-2020 12:52 PM
Mine use something like a mini button catch to hold them in place. Easy in, easy out for cleaning.
-- Sawdust Maker
View LeeRoyMan's profile
LeeRoyMan
1189 posts in 503 days
#6 posted 06-04-2020 01:08 PM
C.R.Laurence makes some extra strength double sided tape,
or just use silicone.
-- I only know what I know, nothing less, nothing more -- That doesn't count what I used to know..
View BlueRidgeDog's profile
BlueRidgeDog
703 posts in 555 days
#7 posted 06-04-2020 01:39 PM
If you want Muntins, you can silicone them on, or clip them on. Commercial fake ones are clipped so you can remove them and clean the glass etc.
1thumb
#8 posted 06-04-2020 01:42 PM
- LittleShaver
I’m aware of those, but not what I want. These are glass slabs, set into a frame and stopped w/quarter round. Similar to how you’d a transom. Build frame, run stop, set in glass, run more stop
1thumb
#9 posted 06-04-2020 01:44 PM
- LeeRoyMan
Clear silicone. Thanks. I’ve come across, velcro hot glue, clear gorilla glue, but i think clear silicone will be best
View Jared_S's profile
Jared_S
351 posts in 736 days
#10 posted 06-04-2020 01:54 PM
Search “simulated divided light tape” or sdl tape.
It’s common and there is a entire industry around it.
1thumb
#11 posted 06-04-2020 03:59 PM
It s common and there is a entire industry around it.
- Jared_S
I like it, but that one and done, insta grab worries me. Be individual pieces, not a completed unit.But I’m looking at it.
View Kazooman's profile
Kazooman
1492 posts in 2729 days
#12 posted 06-04-2020 04:12 PM
How thick are the glass “slabs”? I suggest making a simple mock-up before you get too far along with this. I think that you will easily be able to see the backsides of the fake muntins. I have a couple of steel entry doors that have thermopane glass held in place by being sandwiched between two fiberglass grids made to give the divided light look. A very common design. You can easily see the backside of the grids.
Jared_S
#13 posted 06-04-2020 04:21 PM
- JaredS
- JaredS
I like it, but that one and done, insta grab worries me. Be individual pieces, not a completed unit.But I m looking at it.
- 1thumb
Like regular glazing tape, its typically a destructive process to remove once adhered.
Any reason you are not doing them as a single grid unit? Individual bars would not be typical.
1thumb
#14 posted 06-04-2020 04:45 PM
- Jared_S
Not a typical installation, but it’s what she wants. Applied wood mullions, cut to fit. Run longer verts first, cut horizontals to fit. Cut those mullions 100’s of times, a 55 or so degree cut lays that long point nicely onto mull so as it planes out w/flat of existing mull. Can’t put together as one piece
https://www.homedepot.com/p/Alexandria-Moulding-WM-984-3-8-in-x-1-3-8-in-x-96-in-Wood-Pine-Mullion-Moulding-0W984-20096C/205958690
