wall hanging corner shelf
Forum topic by plang posted 05-29-2020 01:44 AM 198 views 0 times favorited 2 replies Add to Favorites Watch
View plang's profile
plang
136 posts in 4232 days
05-29-2020 01:44 AM
Hello all.
My grandson has built the Lego Saturn V rocket and i am planning to build a hanging corner shelf for it. The rocket is over 39 inches tall and 6 inches in diameter. the two sides and front will be glass with a wood frame from Cherry. If you have built anything like this would you please send pictures. Thanks in advance.
2 replies so far
View Madmark2's profile
Madmark2
1698 posts in 1465 days
#1 posted 05-29-2020 01:55 AM
Have you thought of adding an LED accent light in the top? You can get a multicolor LED remote controlled waterproof 3x AAA battery puck with built in magnet and mtg plate at Walmart for $10. Makes a great night light for a kids room.
Use lexan instead of glass.
Rockler sells “space balls” that prevent the glass/lexan from rattling.
Kick the platform back a degree or two to bias it backwards into the corner to make it less tippy
-- The hump with the stump and the pump!
View ChefHDAN's profile
ChefHDAN
1769 posts in 3727 days
#2 posted 05-29-2020 01:50 PM
Corner Shelf with three sides? Wall Hanging…
Agree with Mark, Lexan will be less expensive, lighter and MUCH safer than picture glass
Maybe a simple box frame with dadoes in the two faces into the room to hold the lexan, to keep it simple, I’d likely do a drop on top that could hold the light Mark suggests. Wall attachment is just a cleat under the shelf, you should be able to hit a stud in the corner and then some snap toggles would be plenty to hold it.
