Table saw ripping out of square
Forum topic by Ken Masco posted 05-28-2020 05:42 AM 889 views 0 times favorited 13 replies Add to Favorites Watch
View Ken Masco's profile
Ken Masco
903 posts in 4140 days
05-28-2020 05:42 AM
I have a grizzly 691 cabinet saw. I’ve had it about 10 years, it has performed flawlessly. Last week I noticed while ripping, the stock was drifting away from the fence. Turns out one of the nylon adjustment bearings fell out. After I got it back together and pretty well aligned. While ripping 8/4 walnut and found the stock out of square. The tilt was off ever so slightly so I adjusted it and made the cut again, same problem. So I tried another square and sure enough the blade is square to the table but the cuts are not square. Is this even possible? It was getting late so I shut down and will look at it again. Perhaps I’m just dumbed down after a long shop day. Have any of you experienced anything like this?
-- Ken
13 replies so far
View toolie's profile
toolie
2210 posts in 3918 days
#1 posted 05-28-2020 11:31 AM
Yup. Sometimes you get so far past the point where the mind works sharply enough to recognize problems it’s best to take a break. The eyes you’ll have when you return usually see things tired eyes don’t see.
View Robert's profile
Robert
4798 posts in 2770 days
#2 posted 05-28-2020 01:38 PM
Jointed face down?
I don’t know any other way this could happen other than a cup in the board & you’re pushing it down against close to the fence. DAMHIKT.
View hcbph_1's profile
hcbph_1
105 posts in 604 days
#3 posted 05-28-2020 02:53 PM
You imply (if I’m reading your statement correctly) the blade is correct to the saw top. By that I assume you mean to the miter slots. How about the fence, is it square to the miter slots?
View Kazooman's profile
Kazooman
1540 posts in 3242 days
#4 posted 05-28-2020 03:18 PM
If I understand correctly, you are saying that the cut face is not perpendicular to the face that was down on the table, even though you have checked that the blade is right on at 90 degrees. Have you checked to see that the face of the fence is also still 90 degrees to the table surface. Perhaps something got out of whack when yo u were adjustment bearing. Are you using a thin kerf blade? If something is out of square you might get a tiny bit of blade deflection, but I think that would be apparent.
Ken Masco
#5 posted 05-31-2020 07:24 AM
Thank you all for your responses. This is one of those mystery things that cannot be understood. Today was my first day back in the shop. I picked up where I left off and those three boards I cut were not square. I checked and double checked that the fence, the blade and the slots were all parallel and the blade was precisely at 90 degrees, It all checked out. I didn’t make any changes. I jointed the bad boards and continued with the project. By mid afternoon I needed to make another rip cut off the same 4square Plank and it cut perfectly square, and continues to do so. I have no explanation. However it is really nice to have you all to help me not only on this latest situation but several over the years. You are a great bunch. Thank you again.
-- Ken
View Jim Finn's profile
Jim Finn
2905 posts in 4212 days
#6 posted 05-31-2020 12:35 PM
I occasionally have tis problem also. I blame my problem on my pushing technique. Doing something wrong.
-- No PHD just a DD214 Lubbock Texas
View RCCinNC's profile
RCCinNC
526 posts in 1616 days
#7 posted 05-31-2020 02:51 PM
Sometimes same “Mystery” occurs to me. Another possibility…internal forces in the wood when ripping causing wood to pull slightly away from the fence? Or just shop gremlins, which occasionally love to mess with our heads…; )
-- Live to putter...putter to live!
View D4me's profile
D4me
6 posts in 559 days
#8 posted 06-01-2020 12:37 AM
Extend the saw blade fully. Grab the blade and forceably move it back and forth, then left to right, then pull up then down.
Then do each more gently – any movement in any direction will require looking into.
Then go to the fence and try to move it after being locked down. Same thing. Then check the contact points of the fence and make sure they are not moving on their own (worn out).
Next is to square the fence to the blade using a 2ft or longer metal straight edge (carpenters square will work) and take careful measurements. That’s CAREFUL measurements. You are looking for less than 16ths of an inch, and it better be less, as in as close to zero difference as possible.
This has to be done close to the blade and then as far from the blade as possible in both directions.
If all the adjustments above don’t work – as everything is in tolerance and nothing is moving, then pull out your jack plane and go to work.
View Woodknack's profile
Woodknack
13585 posts in 3670 days
#9 posted 06-01-2020 03:52 AM
Thank you all for your responses. This is one of those mystery things that cannot be understood. Today was my first day back in the shop. I picked up where I left off and those three boards I cut were not square. I checked and double checked that the fence, the blade and the slots were all parallel and the blade was precisely at 90 degrees, It all checked out. I didn t make any changes. I jointed the bad boards and continued with the project. By mid afternoon I needed to make another rip cut off the same 4square Plank and it cut perfectly square, and continues to do so. I have no explanation. However it is really nice to have you all to help me not only on this latest situation but several over the years. You are a great bunch. Thank you again.
- newwoodbutcher
I had the same thing happen last year, my 20 year old saw started tapering boards even after checking and double checking my setup. Then suddenly it stopped. Maybe it was me, maybe it was the lumber, maybe it was the saw bearings starting to wear, no idea.
View theart's profile
theart
233 posts in 1844 days
#10 posted 06-01-2020 12:34 PM
- RCCinNC
When it happens to me, it’s usually due to a little clump of sawdust somewhere that’s keeping the board from sitting tight to the table or fence.
View Nubsnstubs's profile
Nubsnstubs
1808 posts in 3020 days
#11 posted 06-01-2020 01:40 PM
you didn’t mention the condition of your saw blade. Could be dull on one side after hitting something you didn’t notice. Check your teeth tips with a magnifying glass. ............ Jerry (in Tucson)
View Andybb's profile
Andybb
3346 posts in 1893 days
#12 posted 06-01-2020 02:55 PM
- RCCinNC
+1 That would be my guess also.
-- Andy - Seattle USA
Ken Masco
#13 posted 06-01-2020 05:03 PM
Thank you all for responding. The blade is a fairly newly sharpened WWII it’s tight and aligned with the miter slot and fence using an Align It gauge. And was cutting fine all day yesterday. I suppose it could have been wood stresses but cutting additional rips off the same board were fine. Or, it could have been sawdust against the fence. At any rate, the saw is once again performing flawlessly and Lumberjacks continues to be a great resource. Thank you all
-- Ken
