Maximum stock width for Dowel Jigs
« back to Joinery forum
Forum topic by woodetal posted 05-25-2020 03:57 PM 378 views 0 times favorited 5 replies Add to Favorites Watch
View woodetal's profile
woodetal
65 posts in 543 days
05-25-2020 03:57 PM
All! Most of my joinery is M&T. Some biscuits from time to time. I have two projects that need dowels for various reasons. The stock I need to join is @2.25”. It appears the Dowelmax has greater then 2” capacity. Jessem’s max remains a mystery. Other jigs appear very limited in max stock width. What is your experience?
5 replies so far
View LeeRoyMan's profile (online now)
LeeRoyMan
1179 posts in 497 days
#1 posted 05-25-2020 04:07 PM
Ye ole’ General 840 would go to 4” (had to look that up)
This was my first doweling jig.
Way before they had any of the fancy stuff, at least fancy stuff that I knew about.
Drilled hundreds of holes and made just as many blisters, but all and all,
it was pretty descent at lining up holes.
-- I only know what I know, nothing less, nothing more -- That doesn't count what I used to know..
View Rich's profile (online now)
Rich
5608 posts in 1360 days
#2 posted 05-25-2020 07:14 PM
The fence on the JessEm goes back to 3 1/2 inches, so you could put a dowel in the center of a 7 inch wide board. It’s also designed such that you can change the fence setting without unclamping the jig. That allows you to do arrays of dowels rather than a single row in cases where you need extra joint strength.
View therealSteveN's profile
therealSteveN
5754 posts in 1344 days
#3 posted 05-25-2020 09:47 PM
6” width here. $78.50
https://www.dowl-it.com/5
Dowelmax classic does 4”, costs a LOT more, but it also is easier to work, and more predictable results.
https://www.amazon.com/Dowelmax-Precision-Engineered-Joining-System/dp/B00021ULRE
I can see why older Generals are selling for a few hundred bux, they worked well, without a lot of fussing.
-- Think safe, be safe
View LittleBlackDuck's profile
LittleBlackDuck
4673 posts in 1591 days
#4 posted 05-26-2020 05:31 AM
Another one of my not-so cheap advise.
If you can afford it, you could do a lot worse than a Fe$tool Domino… think long term… I avoided it like the plague till they recently released their breakdown hardware… that has moved the goal post to the opposite end of the field.
View AlaskaGuy's profile
AlaskaGuy
5794 posts in 3079 days
#5 posted 05-26-2020 06:11 AM
Maybe you could make your own
https://www.youtube.com/results?search_query=make+your+own+dowel+jig+for+thick+wood+
