Powermatic P60 Outfeed table stuck
Forum topic by ikir posted 05-24-2020 11:48 PM 168 views 0 times favorited 1 reply Add to Favorites Watch
View ikir's profile
ikir
1 post in 41 days
05-24-2020 11:48 PM
Topic tags/keywords: jointer
Hi,
I am looking for help with my Powermatic P60 1983 jointer. I am trying to raise outfeed table as it is below cutter head, but locking screw seems to be stuck – I can’t turn it.
Adjustment arm doesn’t move either. I am out of ideas, would appreciate any help.
Thanks!
1 reply so far
View farmfromkansas's profile
farmfromkansas
182 posts in 383 days
#1 posted 05-27-2020 12:19 AM
Oil will break it loose. Might try PB blaster, but just motor oil will do it if you can get into the right place. Try a thin weight oil. When you do get a tiny bit of movement, just rock it back and forth rather than trying to force a lot of movement at once. If you could find a container the thing would sit in, you could fill with used motor oil which will break it loose quickly. Small parts hanging on a wire in a bucket of oil will break loose in just a day or 2. Patience will help you on this project.
